10-24-2017, 12:21 AM
bilbofett bilbofett is offline
Hi!
Any recommendations for audio cards that will do bitperfect digital recording via TOSlink? (like coaxial/SPDIF)
I'm outputting laserdisc with TOSlink out, many discs have Dolby digital (AC-3) and the regular analogue tracks, (LPCM).
I have Win10 but can do XP if needed for software.
12-13-2017, 10:59 AM
Not that I'm aware of. There were a lot of fancy models in the B&H catalogs 10+ years ago, and I got those at least twice a year. Lots of mixers, reference speakers, and other audio gear. It was always pricey stuff. I have no doubt it had TOSlink connected gear in there, but nothing I ever saw in any store was like that -- even Fry's or Microcenter, which had some high-end computer hardware.
I was video, not audio/music, so no in-depth investigations there. I was needed mixers, Sound Forge, and a few other basic needs.
12-13-2017, 11:25 AM
Do you already have SP/DIF capability? (Common in many legacy audio cards.) If so a TOSLink to SP/DIF converter might do it?
e.g., https://www.monoprice.com/product?p_id=2948&gclid=EAIaIQobChMIlvyUlcCH2AIVUF YNCh19Swr2EAQYBCABEgKQevD_BwE<
12-14-2017, 04:46 PM
bilditup1 bilditup1 is offline
For the LCPM tracks, you may want to look at getting a used Edirol/Roland UA-1EX. eBay has them for $20-30, sometimes a bit more. It has a mini-TOSLINK input and is even compatible with 32kHz content (important for some DAT tapes recorded in this rare sampling rate). It will work without issue on XP, and there is a process for getting it to work on Windows 10 here:
https://www.youtube.com/watch?v=-2aSb4q2Kvw
I have used the patcher and can confirm it works, including with the digital input. It also works with OS X through 10.9 Mavericks (but not after).
Unfortunately I'm not sure how to do bitperfect captures of a bitstreamed AC3 track. You may want to ask at originaltrilogy.com, where members have done a lot of LD cap work.
audio, capture card, laserdisc, spdif, toslink
Recommended Windows 10 capture card? Robinthehood Capture, Record, Transfer 0 09-27-2016 12:24 AM
Recommended capture card with component inputs? metaleonid Capture, Record, Transfer 12 11-17-2013 09:29 PM
Perfect speakers for restoring audio, the Monsoon MH-502 kpmedia Restore, Filter, Improve Quality 1 06-14-2011 11:11 AM
Recording Wii with USB capture card ? via Email or PM Capture, Record, Transfer 1 07-24-2009 08:35 PM
Capture Card Program for Recording Shows JonathanEntertainment Capture, Record, Transfer 3 03-22-2008 03:07 AM
