03-12-2019, 11:55 AM
dabhdude dabhdude is offline
I've been given a VHS transfer project of at least 30 tapes. Upon watching the first two, I was kinda hopeful I could get away with not having to use a TBC since they were, while not perfect, more or less stable. Then I ran across some tapes that were a lot LESS stable (don't get me started on the SLP ones).
So I went looking for a TBC and I found the Grex, which I was luckily told to avoid. I came across a few pretty cheap looking ones on ebay, like this: https://ebay.to/2UsAKn4
I was hoping to use my DV camera as a TBC, but that doesn't seem very possible now. So, any recommendations on what I should use under $100? Like it or not, I'm probably not spending more than that on a TBC, especially if it's just a line one.
03-12-2019, 02:00 PM
Grex is not a TBC, and has many side effects, the worst being similar to a bad AGC. The only time that I've found a Grex useful is when removing known copy protection between DVD recorders. So DVD recorder analog out > Grex > analog in to another recorder or capture card. That's because some PITA recorders prevent easy copying of programs, either burned to disc or simply re-captured. For that, the Grex helps. But for analog tapes, forget it, crap.
Those "video stabilizer" boxes were just a nonsense device sold to gullible suckers in the 90s. It does almost nothing, the reason it costs almost nothing. And honestly, it's worth $0.
There are no external lines TBCs. However, a Panasonic ES10 or ES15 comes close. It'll still choke on copy protection, and some other errors, but it can salvage excellent quality (signal quality, not necessarily visual) homemade tapes. Though it should improve quality some.
An external framesync TBC is not a line TBC. Line TBCs are generally found in S-VHS VCRs.
An external TBC is the only guaranteed way to remove copy protection. (Excluding DVDHDD>digital, where the Grex is better, oddly enough.)
My advice? Get that ES15 for about $100
Here's one: http://rover.ebay.com/rover/1/711-53...m/123680094723
But be warned!!! eBay sellers are notoriously bad for lying about quality, "forgetting" to mention problems/defects, and for pathetic padding-less shipping. You may end up with a box full of busted plastic and metal (due to zero padding) that smells like an ashtray. I'm not exaggerating, that is exactly what happens, and often. But if you want cheap, under $100, you're in gambling territory. Trying to save 100 bucks may end up costing 100 hours in grief.
cheap, recommendation, tbc
Hi8 capture HW/SW recommendations? djam0000 Capture, Record, Transfer 9 01-19-2026 04:22 PM
DVI KVM switch recommendations? VideoTechMan Computers 2 03-02-2016 04:20 AM
Anyone got recommendations for transfer PC? Danfun64 Capture, Record, Transfer 1 03-04-2015 08:16 PM
Recommendations for VHS filtering? blud Restore, Filter, Improve Quality 1 04-10-2012 01:21 PM
DVD Player Recommendations? mitch Videography: Cameras, TVs and Players 5 03-18-2005 07:05 AM
