09-14-2007, 01:01 AM
stoogedog stoogedog is offline
hi, i am getting some pal discs and i have a player that will play pal discs. if i play a pal dvd in the one player and connect it to my standalone recorder, will the disc that i burn be ntsc or pal? i'm thinking that i would be ntsc. please let me know your thoughts on this. any and all input appreciated. thanks stoogedog
09-14-2007, 02:00 AM
wheezer210 wheezer210 is offline
The recorded disc will be in NTSC format. The PAL player converts the signal to the correct resolution and frame rate.
09-15-2007, 04:41 AM
Actually, it depends. Most machines don't convert. They play 25fps into a 30fps window, and is why you may see ghost streaks. Many machines crop pixels off top and bottom (sometimes just bottom), rather than resizing the palette. The color is output in NTSC values instead of PAL values. The DVD does not have "PAL" or "NTSC" color, but rather the player output DVDs as analog signal, and that's where the color values come from. PAL encoded DVDs often have "hot" or "oversaturated" colors when PAL output is intended, so if you're converting using a disc to disc playing method, you may consider a proc amp in between, to reduce the saturation a tiny bit. Overwise, the new NTSC DVDs may have color bleeding on reds and greens. You may notice this playing PAL on NTSC, and that's one reason I have color modes on my tv (one mode de-saturates).
Just a few things to remember and consider.
Because universal playback quality improves every year, I'm not a fan of converting. Your conversion job this year may look worse than just playing the PAL DVDs as-is in another 1-2 years.
External DVD recorder - is USB2 required ? stoogedog Computers 7 02-27-2008 02:44 PM
Keepvid techie question - How to burn videos to a disc ? stoogedog Computers 1 02-02-2007 12:16 PM
This might be a silly question to yall but ... stoogedog Encode, Convert for streaming 2 07-18-2005 02:28 AM
