08-31-2007, 08:19 PM
Konfusion Konfusion is offline
Im asking a question for a friend. he as recorded a movie thats raw file is 12 or 13 GB in size the mpeg2 file. What can he do to down convert it to 4.7 so he can put it onto a dvd. he will now change settings that record at 4-8 gb instead but he needs to be able to change this file as the movie might not air again. all burning/authoring programs wont support it.
09-03-2007, 06:06 AM
1. Split it to multiple discs.
2. Re-encode (do not "shrink") the file with an MPEG encoder, to a smaller size.
If the movie is rare, the first option might be best.
Converting avi's to Mpeg/s rockettj1225 Encode, Convert for discs 1 02-08-2009 04:22 AM
Converting Mpeg files to Avi files?? MagnificentMarcus Encode, Convert for discs 2 02-24-2008 06:18 AM
Tsunami DVD MPEG Pro help, audio stream missing? fortunec00kie Author, Make Menus, Slideshows, Burn 7 04-23-2006 05:42 PM
AVI vs mpeg SavageAmusement Edit Video, Audio 5 03-24-2006 04:24 PM
MPEG-2 vs. MPEG-2 DVD in MMC TV Capture JimGorsline Capture, Record, Transfer 4 07-09-2004 02:20 AM
