12-06-2011, 11:23 PM
via Email or PM via Email or PM is offline
Site Staff Bot
Hi Lordsmurf,
I was reading your comments on using MainConcept Reference for encoding MPEG-2 files for DVD.
(http://forum.videohelp.com/threads/3...-Encoder-Today)
I've been trying to use MainConcept Reference to encode a 7:30 short film, from Cineform avi 1920x1080 to MPEG-2 / DVD. But a strange thing happens -- the video will stop playing early -- say at 7:12 or 6:30, etc (it varies on encode), yet the file will continue "playing" till 7:30.
When I import the MPEG-2 file into Adobe Encore, the video file shows up as a 6:30 or 7:12 length file. But if I drag the end of the file out past its "end point", the following footage appears (ie, after 6:30 or 7:12). Unfortunately when I burn a disc image, the DVD only plays up to 6:30 or 7:12, then the video stops while the sound continues to 7:30.
I figured I'd try asking you about this, as I can't find anything online about it. I ran an encode with Adobe Media Encoder (guessing Mainconcept SDK?), and while it worked fine, it looks really terrible compared to the Mainconcept encode -- much darker and poorer colors. So if I can't get Mainconcept to work, then I guess the next step could be an encode with HCenc? Thanks for any advice you can offer!!
Ram
-- from fjolafilms
JVC DR-M100S Resolution and Bitrate Reference Sheet robjv1 Capture, Record, Transfer 2 09-18-2011 06:00 AM
Invalid Application error - Facebook Like/Recommend button stops showing [FIXED] kpmedia Website and Server Troubleshooting 0 03-15-2011 10:44 PM
Is onboard sound OK for VHS home video capture? GroverXpup Capture, Record, Transfer 5 12-02-2010 07:17 PM
Recommended upload video format for maximum sound quality on youtube waigy Encode, Convert for streaming 21 09-01-2010 03:37 PM
How to capture video/sound via ATI AIW? thienng Capture, Record, Transfer 4 07-23-2004 12:56 AM
