04-01-2012, 11:14 AM
via Email or PM via Email or PM is offline
Site Staff Bot
Hi Lordsmurf, I was reading your comments on using MainConcept Reference for encoding MPEG-2 files for DVD. I've been trying to use MainConcept Reference to encode a 7:30 short film, from Cineform avi 1920x1080 to MPEG-2 / DVD. But a strange thing happens -- the video will stop playing early -- say at 7:12 or 6:30, etc (it varies on encode), yet the file will continue "playing" till 7:30.
When I import the MPEG-2 file into Adobe Encore, the video file shows up as a 6:30 or 7:12 length file. But if I drag the end of the file out past its "end point", the following footage appears (ie, after 6:30 or 7:12). Unfortunately when I burn a disc image, the DVD only plays up to 6:30 or 7:12, then the video stops while the sound continues to 7:30.
I figured I'd try asking you about this, as I can't find anything online about it. I ran an encode with Adobe Media Encoder (guessing Mainconcept SDK?), and while it worked fine, it looks really terrible compared to the Mainconcept encode -- much darker and poorer colors. So if I can't get Mainconcept to work, then I guess the next step could be an encode with HCenc? Thanks for any advice you can offer!!
Ram
--fjolafilms
04-01-2012, 11:32 AM
It sounds like the source video is corrupted. Or the hard drive is.
When MainConcept Reference fails, there's a red X that you can click, and it shows the exact error message.
If MainConcept won't work for MPEG-2, use Avidemux (ffmpeg). It's not quite as good, not "the" best, but it's not bad either.
I use it when not doing pro work, and not at my own systems.
Frameserve from Premiere CS4 to Main Concept Reference naripeddi Encode, Convert for discs 3 12-14-2011 02:14 AM
Strange Mainconcept Reference error... video stops while the sound continues ? via Email or PM Encode, Convert for discs 0 12-06-2011 11:23 PM
JVC DR-M100S Resolution and Bitrate Reference Sheet robjv1 Capture, Record, Transfer 2 09-18-2011 06:00 AM
What settings -- f/stop, shutter speed, ISO, & focus -- for shooting artwork ? Sossity Photo Cameras: Buying & Shooting 3 12-11-2010 11:27 AM
Encode or re-encode, one progran as good as another? cyber-junkie Encode, Convert for discs 1 08-13-2010 05:05 PM
