02-17-2016, 09:44 AM
Mejnour Mejnour is offline
Hello,
I extracted from a DVD a interlaced m2v file with PgcDemux and once I edited and saved AVI with Virtualdub I endend with a progressive AVI file.
Is that normal?
02-17-2016, 10:14 AM
Goldwingfahrer's Avatar
Remembered
Is that normal?
yes
PGCDemux writes yet
video
Audio and SUBPIC in separate streams
Why You take VDub, you want "a" stream in AVI?
Do I cut the mpeg2 stream
I put video m2v + Audio AC3 [or mpeg1 Layer2] in Womble.
At the end there is a new mpeg2 stream .....without new encoding
The following users thank Goldwingfahrer for this useful post: lordsmurf (04-26-2016)
02-17-2016, 10:34 AM
I use this tutorial to correct audio and video from poor homemade quality DVD.
Thanks for the answer I will edit my video in premiere pro where I know I can keep the video interlaced.
02-17-2016, 11:24 AM
Remembered
AviDemux and VDub I put not one for editing mpeg. 2
mpeg2 cut with Womble or xilisoft video cutter 2 ... without re-encoding.
"Premiere Pro"
yes why not, as is but all re-encoded
I have Adobe CS6
When used to mpeg2 filter then must always be re-encoded.
The instructions in the link is incorrect.
VDub can output to AVI from mpeg2 streams
AviDemux 2.6.11 still can not encode MPEG2 by interlaced
Last edited by Goldwingfahrer; 02-17-2016 at 11:31 AM. Reason: improved translation
VCR and VirtualDub VHS capture settings and advice sanCapture Capture, Record, Transfer 2 01-26-2014 05:28 PM
HuffyUV Settings with VirtualDub for capture naripeddi Capture, Record, Transfer 7 04-12-2013 02:50 AM
Cannot unzip network file: 'Your current security settings do not allow this action' kpmedia Computers 0 09-08-2011 02:29 AM
VirtualDub - advice on the filter settings deter Restore, Filter, Improve Quality 7 01-21-2010 09:54 PM
