10-18-2006, 03:23 PM
MagnificentMarcus MagnificentMarcus is offline
Or can you? I have some shows that are in mpeg2 format;I want to compress them to put them on a disc and then put menus on them. Can I do this??
10-18-2006, 03:40 PM
markatisu markatisu is offline
Marcus MPEG2 usually refers to native DVD format (though SVCD can be called that as well), its basically whats inside the VOB files you get from the DVD Recorder.
When you say compress do you mean shrink? Or did you just want to author the mpg files into a DVD with menus?
Need more specifics
10-18-2006, 05:29 PM
I want to shrink them or compress them to 4.35 g. They are current 6.15 gs.
10-18-2006, 11:11 PM
MPEG-2 is already compressed video.
You would do better to just author and burn those directly to DVD+R DL media, unless it's professional studio material (but even then, it may not shrink/transcode well).
I would re-encode everything in Procoder to 352x480 with a bitrate no less than 2500k, if I was unable to use DL media.
What are ZIP and RAR files? + How to use them admin Computers 4 03-12-2013 03:27 AM
Converting Mpeg files to Avi files?? MagnificentMarcus Encode, Convert for discs 2 02-24-2008 06:18 AM
Converting a 12GB Mpeg to a 4GB Mpeg Konfusion Encode, Convert for discs 1 09-03-2007 06:06 AM
Preview files Wineslurper Restore, Filter, Improve Quality 2 07-06-2005 08:18 AM
MPEG-2 vs. MPEG-2 DVD in MMC TV Capture JimGorsline Capture, Record, Transfer 4 07-09-2004 02:20 AM
