If you have Premiere Pro, it's quite easy. You just have to Dr the VOB files in, which will work most of the time. But I assume you will not have access to that, so what editing software will you be using?
I believe there are a few rare players that can play files other than VOB, but don't count on it.
I don't know if this would work, but there is a website called clip converter.cc where you can upload a clip and convert and/or cut it. When converting from YouTube, the website lets you choose the in and out time. If this option is available upon uploading a file, and they accept VOBs, you should be all set.
