07-08-2023, 01:55 PM
grun_socken grun_socken is offline
I'm doing a video project about the Joplin tornado and it involves syncing lightning and power flashes to other videos. All my other videos are synced perfectly but this one video has an issue where at one portion of the video the timing seemingly breaks and completely misaligns with the rest of the video.
In the attachment I uploaded you can see the issue , where both videos on top and bottom align, and then as it gets further along the timeline the video on the top completely loses sync. The video in question (which I also uploaded) is ripped from a security camera so if I had to guess probably the original uploader's camera must've been damaged in the tornado and the resulting video was bugged out. I just want to know if there's any kind of I way I can change the video speed or if this video's salvageable.
07-08-2023, 03:50 PM
I'm not getting any audio at all on that clip.
Where did that video come from? It's obviously been re-encoded, probably multiple times now. It's not at all original from a camera, and re-encoding damage is the usual reason for a/v timing mismatch.
"ripped" is not captured. More details need to be known on the chain of custody, from original camera to what's attached.
07-23-2023, 10:52 AM
Hey, so I did some digging and I managed to find the original source of the video before all the reposting, here it is, it was uploaded 2 days after the tornado and the channel it comes from has two different videos from different angles. I noticed that on all the videos they posted all the videos had some kind of severe timing misalignment, the videos will randomly shift from being either sped up or sped down. What do you reckon from here?
07-24-2023, 07:29 AM
I get no audio on the youtu.be clip either.
The EMP associated with a lightning stripe may have messed up the recording system causing lost frames of audio and/or video de-syncing it.
I would use a NLE to adjust audio/video sync in a clip and as necessary adjust augio or video playback speed to match other clips. A good VLE will also show audio waveforms to help in this process. (Usually better to change audio speed rather than video speed because audio has much finer granularity (e.g., 48k samples per second vs 30 frames per second).
Maybe it is too obvious but sound from lightning will always come after the flash; about 1 second for every 1000 feet.
Timing Resync Options with ATI 600 USB? gloubu Capture, Record, Transfer 0 04-03-2021 01:19 PM
Capturing miniDV recorded with misaligned heads? photoguy1234 Capture, Record, Transfer 2 01-14-2018 11:44 PM
Example of misaligned 8mm, cannot be restored [VIDEO] admin Restore, Filter, Improve Quality 0 11-06-2009 10:02 PM
Soundforge is best tool to restore audio admin Encode, Convert for discs 0 05-29-2004 06:37 AM
