03-08-2015, 04:28 PM
hysteriah hysteriah is offline
I belive the title sais it all?
I've captured a lot of VHS tapes with my ATI AIW 7500 card to my computer with YUY2 color space using the HuffYUV or lagarith codec as suggested on this site.
Now I will need to edit a lot of these footage. I will probably not need to add any effects or transitions to them. I just need to do some very advanced cut and joining between more then 30 files. I find it very hard to work with this large amount of footage in VirtualDub. I think it will be so much easier to do this with a more advanced editing software like Adobe Premiere. But will Adobe Premiere convert my footage to RGB when I drop them to a sequence and cause quality loss when I export them back to YUY2? If not; what sequence settings and export settings should I use to prevent this color space conversion and quality loss from happening?
By the way, I'm using Adobe Premiere CS5.5.
Will these settings do?
SEQUENCE SETTINGS:
EXPORT SETTINGS:
Huffyuv YUY2 AVI to Blu-ray conversion? (and TBC samples!) vhsdigital34 Project Planning, Workflows 264 04-19-2018 05:14 AM
Adobe Premiere Version Validation sirbyron Edit Video, Audio 3 03-02-2015 08:19 PM
Editing HD camcorder footage on older computer? naripeddi Edit Video, Audio 2 07-21-2014 02:37 AM
Is there an alternative to Adobe Premiere? rappy Edit Video, Audio 1 12-27-2011 12:31 PM
