01-07-2015, 09:40 PM
JLegnon JLegnon is offline
I'm looking for software to easily export audio from an MPEG2 video , so I can process the audio in PRO TOOLS , then import the processed audio back to the MPEG2 video .
I have Womble , but I don't think it can do this .
Thanks !
01-08-2015, 04:52 PM
You need to demux (demultiplex) the audio from the video.
- TMPGEnc Plus 2.5 is my favorite demux tool.
- Batch Demux is a good freeware tool, but has some quirks.
- Avidemux is often good, but it can crash a lot.
The following users thank lordsmurf for this useful post: JLegnon (01-09-2015)
01-09-2015, 10:31 AM
As always Mr. Smurf thanks for the advice .
I bought Womble after reading one of your guides and its a great easy to use program . I'll try the free ones first and if I have problems I'll get TMPGEnc Plus 2.5 .
12-18-2015, 05:51 AM
Goldwingfahrer's Avatar
Remembered
In mpeg2 the audio to Wave or MPEG 1 Layer 2 or AC3 is available.
Audio is processed but in Wave .... Audacity, Adobe Audition, Wavelab, Samplitude .....
So you can also open the mpeg2 in VDub and there spend directly in Wave.
Womble is a good tool, I have been around since the first version.
Can't import ac3 audio into DVDWS2 rbatty Author, Make Menus, Slideshows, Burn 2 06-21-2010 02:10 PM
DVD Workshop audio import problems Superstar Author, Make Menus, Slideshows, Burn 22 02-28-2010 09:05 PM
Adobe Premiere 6.5 Timeline Export Extremely Slow... SSStudio Edit Video, Audio 31 12-02-2009 02:19 PM
Looking for DVD to audio software? benjam138 Encode, Convert for discs 3 12-17-2008 05:47 PM
Timeline to DVD Recorder? (Export DV from computer to DVD) couldbe Capture, Record, Transfer 5 09-17-2004 05:41 AM
