03-05-2006, 07:19 PM
manthing manthing is offline
i have some music dvds from which i'd like to extract the audio.
now, i know how to extract the video.
i've also read somewhere that i should demux the audio and then use something like besweet to extract the song and keep it as a wav file.
i have 3 Qs:
[1] is there a 1 click solution?
[2] if i use an editor to cut the sections of music i want from the complete dvd, will i be hacking up the audio? in other words, should i extract all 2 hours worth of audio as a wav file and then cut the sections i want?
[3] if besweet is the best tool, is there any settings i should be aware of?
thanks in advance.
03-05-2006, 07:23 PM
[1] Not a reliable one, no.
[2] Maybe, maybe not.
[3] Just use the correct settings. There is only one choice for format (WAV Stereo).
What you want to do:
1- Play DVD in PowerDVD. Take notice of the chapters of the audio you want.
2- Rip in DVD Decrypter, in IFO mode. Only rip the chapters you want, by selecting or deselecting the boxes.
3- Convert the assumed AC3 to PCM WAV stereo in Besweet or another AC3-to-WAV audio tool. FFMPEG is another one.
4- Dump WAV audio into an audio editor like SoundForge. Edit as needed.
Done.
03-05-2006, 08:22 PM
ta lordly. will do it the way you suggested.
Converting my albums, ripped in FLAC, to Apple Losseless ? Sossity Digital Devices 1 10-31-2011 09:18 AM
Converting .flac audio files to a CD burnable format, to reburn on Mac and Windows Sossity Computers 10 06-29-2011 08:34 PM
Free software to convert audio cassettes on my Mac ? kpmedia Computers 0 09-07-2010 05:16 AM
Convert audio cassettes directly to CD's, without computer? admin Encode, Convert for discs 0 09-04-2010 10:04 AM
How to Convert AC3/MP2 to WAV for Restoring Audio lordsmurf Restore, Filter, Improve Quality 8 03-10-2009 02:42 PM
