06-20-2021, 02:35 PM
michelhammamet michelhammamet is offline
Hey guys,
Hopefully you can help me with this. I am frustrated as I do not like the quality of the output no matter what.
I have a problem. When I rip them I see a sort of waviness on some 2nd gen tapes. Could you please advise what could be wrong here.
Here are some capture screens (if needed i can upload videos later):
https://drive.google.com/file/d/1LET...ew?usp=sharing
https://drive.google.com/file/d/1aF6...ew?usp=sharing
My settings:
JVC HR-S7600
TBC = off
B.E.S.T. = off
PICTURE MODE = normal
+ Panasonic DMR-ES10 TBC (AV4) + Philips DVDR3305
What do you think can cause this irritating effect? At first I thought that DVD recorder, but then i think it is a VCR. Or could it be working as designed as the original recording was from TV broadcast.
I appreciate your input in advance.
06-20-2021, 05:26 PM
timtape timtape is online now
If the first generation was played back without correction, the line errors will be baked in to the second gen. TBC now can only correct your 2nd generation errors. That's my understanding anyway.
06-20-2021, 07:07 PM
I don't think that it is TBC related, though. But more the source recording quality? Just my assumption. But i appreciate your answer @timtape
06-20-2021, 10:25 PM
My point is if the errors in just the 2nd generation playback are only small compared to the first gen errors, you may not notice when those 2nd gen. errors are corrected as they will be overwhelmed by the baked in errors which cant be corrected. So even though the TBC is doing its job, the difference may not be that noticeable. But I'd still use the TBC.
06-20-2021, 11:48 PM
Attach sample images and clips to forum posts, if you want Site Staff to answer.
Capturing VHS tapes is not "ripping". "Ripping" is a reserved term for extracting digital data. It can be container-less, like ripping audio CDs. Or it can be converting the file system, often augmenting data in the process, like ripping DVDs. This is a pet peeve of mine. Terms matter.
The following users thank lordsmurf for this useful post: michelhammamet (06-21-2021)
Various bad captures, what to do? llacb47 Capture, Record, Transfer 4 07-19-2020 11:00 PM
Is it possible to do better VHS captures? Aerith Project Planning, Workflows 11 05-14-2020 03:08 PM
Example Captures: good/bad VCR with/without TBC homefire Capture, Record, Transfer 0 05-14-2019 08:10 PM
ATI All In Wonder helps PAL captures? Luca T Capture, Record, Transfer 20 01-11-2016 03:32 PM
