03-24-2022, 01:24 PM
Darkmatter Darkmatter is offline
I've only seen this on this one tape, so I'm assuming it's damage to the tape itself, but I thought I'd ask.
03-24-2022, 04:34 PM
Looks a bit like the effect you get when playing a SVHS tape in a normal VHS deck (without SQPB), or damaged heads.
If other tapes are ok it's probably something that happened when the tape was recorded rather than tape damage. Looks a bit like it could have been a dub from a tape playing on bad deck or SVHS recording in VHS deck.
03-25-2022, 01:32 PM
Actually that makes it even weirder. There were 2 tapes, both made at a small company that did commercial tape productions for people. They're short videos so the 2 tapes are both the type that have big spools and not a lot of tape.
Both made at the same place at the same time, and 1 works fine and the other looks like that. Considering all this, should I assume that it's tape damage? I don't suppose there's a fix for it?
DM
03-25-2022, 01:53 PM
You can assume if that makes you happy but that's not how problems get solved, Have you read the above post and made an effort upon it to see what format is recorded on tape?
If you want help post pictures of the tapes, a short clip and the hardware used to play it back, if you choose to assume there is no need to start a thread.
03-25-2022, 04:47 PM
Look for the S-VHS coding hole in the cassette bottom. If absent it is not likely a S-VHS recording.
03-26-2022, 01:57 PM
I checked and they are SVHS tapes. Odd that the one played fine and the other didn't, but at least now I know the issue. I've been looking for a S-VHS player locally but haven't had much luck. I also can't afford one of the good ones currently. :/
03-26-2022, 02:59 PM
Keep an eye on local thrift shops, Salvation Army stores, yard sales, etc. Every so often a working one might show up for a nominal cost. Good luck in the hunt. If you find one, test it with a scratch tape first to verify it doesn't eat tapes.
A member here might live near you and be able to check it for you.
Plain VHS VCRs will record VHS mode on SVHS tape. SVHS recorders will normally record VHS mode on VHS tape. Might have had a mixed bag of VCRS in the tape makers dup rack.
Beta tape is this dropped frames or the player or the tape? waloshin Capture, Record, Transfer 1 01-02-2021 03:58 PM
Panasonic NV-HS830 stops tape, rewinds before tape end? bakerie Video Hardware Repair 6 04-16-2020 04:10 PM
How to copy DV tape to new DV tape with audio removed? via Email or PM Edit Video, Audio 1 09-13-2012 05:55 PM
VHS tape malfunction, mechanism not rolling tape properly admin Capture, Record, Transfer 0 10-12-2009 10:57 PM
