01-21-2024, 08:24 AM
ThumperStrauss ThumperStrauss is offline
I transferred Super8 film with company using Lasergraphics Scanstation (2K HDR scan). So the scan as good it gets pretty much. The scene was shot indoors and has lots of noise. I used Selur Hybrid (Vapoursynth) to remove noise (QTGMC +6) and TemporalDegrain (default settings) but it didn't have much impact.
Based on the screenshot of raw footage, is this considered noise or grain? And which filter should I consider using?
P.S. In a separate process, I denoised the scene in Premiere Pro with NeatVideo5 and that did a nice job.
01-21-2024, 08:58 PM
That's chroma noise, easy to remove in VirtualDub with CCD filter.
Avisynth/Vapoursynth cNR filters are inferior.
The following users thank lordsmurf for this useful post: ThumperStrauss (01-22-2024)
01-22-2024, 10:59 AM
Selur Selur is offline
Share a short snippet of the source not a screenshot, if you want further suggestions
01-23-2024, 08:57 AM
cbehr91 cbehr91 is offline
I wouldn't consider myself a wizard at Avisynth by any means, but I have been using a combination of TemporalDegrain2 and RemoveDirtMC at low settings (never above 40, usually 20 or 30) to denoise Super 8 films digitized by an old MovieStuff Retro8.
The following users thank cbehr91 for this useful post: ThumperStrauss (02-26-2024)
Cannot adjust Dynamic Noise Reduction filter in VirtualDub? bmichaelb Restore, Filter, Improve Quality 3 08-12-2022 11:30 PM
Hybrid/Vapoursynth is crushing shadow detail? bradgranath Restore, Filter, Improve Quality 14 02-10-2022 02:19 AM
VapourSynth + QTGMC Deinterlace + Hybrid FAQ for macOS ELinder Restore, Filter, Improve Quality 0 03-16-2020 09:01 AM
Best filter to remove white snow noise? dima Restore, Filter, Improve Quality 1 01-22-2020 11:01 AM
When to use the Panasonic VCR built-in Noise Reduction filter? hysteriah Capture, Record, Transfer 2 04-21-2015 04:14 AM
