03-23-2025, 01:18 PM
DigiTime12 DigiTime12 is offline
I am using AVIsynth+ and the only plugin I have found is an old plugin called DVInfo that displays the DV date and time on the file. The plugin is very old however and I believe it was made for the original Avisynth and not avisynth+. I have tried using LoadPlugin but it says it cant load a 32bit plugin in 64bit avisynth.
I am aware of the DVdate software that I have used before to watch the original DV AVI files with the date but I am intending on converting and compressing the files and attaching the time and date onto the video so its displayed on there directly.
Does anyone know how to get this plugin working or any other method to get the DV time and date displayed using Avisynth?
03-24-2025, 04:58 AM
Selur Selur is offline
a. you could ask over at doom9s if someone could make a 64bit build of it,...
b. you could use MP_Pipeline to use a 32bit plugin in 64bit Avisynth. (see: https://forum.videohelp.com/threads/...-with-AviSynth)
avi, avisynth, dvinfo, plugin
Tool for extracting Hi8 date and time cwig Capture, Record, Transfer 6 10-15-2023 04:26 PM
How to remove flashing date/time from VHS capture? NewToCapturing44 Restore, Filter, Improve Quality 37 08-20-2021 01:15 PM
Date + time stamp from Digital8 or Hi8 video? sublimesed Capture, Record, Transfer 2 01-19-2021 01:42 PM
Date and time embossing on digital camera photos naripeddi Photo Processing, Scanning & Printing 4 04-12-2012 01:41 AM
Date and time embossing on DV files ? naripeddi Edit Video, Audio 2 04-09-2012 10:47 PM
