08-30-2025, 10:46 PM
henryperu77 henryperu77 is offline
Hi
I used avisynth to clean this video and upscaled it , but it still have this color lines/artifacts on the reds and yellows...
https://drive.google.com/file/d/1vz9...ew?usp=sharing
what filter in avisynth i should use to remove them before i upscale it
this is the upscaled result where the artifacts are very noticeable
08-31-2025, 12:42 AM
Aya_Rei Aya_Rei is online now
Are you talking about the dot crawl? You can try this VirtualDub plugin
Or maybe some dotcrawl filters for AviSynth..
09-01-2025, 08:40 AM
Selur Selur is offline
I agree in Avisynth/Vapoursynth filters to remove dot crawling like Checkmate should work fine,...
Betacam color artifacts? CHOXUWU Capture, Record, Transfer 5 03-08-2025 09:39 PM
How to remove audio artifacts after pitch shifting adjustements? monks19 Edit Video, Audio 2 08-27-2021 03:38 AM
Analog transfer to digital, noise artifacts and NeatVideo? Denicio Restore, Filter, Improve Quality 19 05-13-2021 08:09 PM
How to capture and output old analog sources easily? MrEx Capture, Record, Transfer 12 09-01-2020 07:46 PM
DV color space harmful to analog color quality? Verify? DeXeSs Capture, Record, Transfer 6 06-27-2010 01:48 AM
