08-30-2025, 04:39 PM
ddybing ddybing is offline
Hi.
What is your "go-to" methods for removing ringing around sharp transitions/edges, such as in this example shot? There is a halo/ring around the person's white shirt and the background.
I've tried to play around in Staxrip and Hybrid with different DeHalo and DeRing filters but I feel that there is very little, if any, difference.
Is there any true way to remove/reduce the ringing?
Thank you in advance!
09-01-2025, 08:12 AM
Selur Selur is offline
DeHalo_alpha or FineDeHalo would be the first filters I try. (the default values will probably not help)
Share a sample of the unfiltered source if you need suggestions for your file.
Is this ghosting, ringing, oversharpening? iseevisions Restore, Filter, Improve Quality 7 02-19-2024 08:21 AM
Bright strokes around the edges? ThomasFan1945Pro Restore, Filter, Improve Quality 4 05-11-2023 04:42 PM
QTGMC deinterlacing, ringing/halo removal? Cjdavis83 Restore, Filter, Improve Quality 6 11-12-2022 12:40 PM
Strong bleed along edges? What is this? BeerOnABeach Restore, Filter, Improve Quality 3 12-21-2021 12:17 PM
Errors on the edges of converted VHS tapes? xyciana Capture, Record, Transfer 3 09-14-2012 12:44 PM
