03-14-2010, 05:42 PM
restauroman restauroman is offline
Why, Panasonic is not good?
To register in CBR?
03-15-2010, 02:20 AM
Panasonic DVD recorders are riddled with quality problems. These have included:
Early age models (2002-2004):
  • AC3 files that go out of sync when edited in many MPEG editors. (Not fully compliant?)
  • Half D1 encodes are very blocky, for no reason other than the encoder chipset sucked. (Based on equally crappy Panasonic software encoder of the time?)
  • Luma is off, sometimes giving you a muddy green-tinted images.
  • The black level is not correct. The earliest models had awful over-brightness issues, in addition to IRE issues.
  • Even in SP mode, the video quality is noisy, with mosquito noise (pre-blocking artifacts)
  • XP mode bitrate spikes exceed DVD-Video specs, discs refuse to play in some players.
Mid age models (2005-2006):
  • There is not enough bitrate past SP mode, models stupidly insist on 720x480 recording, giving you noisy and blocky encodes
Late age models (2007-2010):
  • Same issues as mid-age models, plus some build quality issues.
All current DVD recorders use either CVBR or VBR -- mostly VBR.
Some early off-brand models (Centrios, Cyberhome) used CBR, but that was ages ago. Most of those machines have long since died and disappeared. I seem to recall a model of Pioneer being CBR, too -- but that was 5+ years ago. (It would have been discussed in a thread in this forum, if my memory is correct.)
Wanted Panasonic DMR-ES10 DVD recorder, to use for bypass rodbuilder Marketplace 10 08-30-2011 02:59 PM
Micro 4/3rds cameras by Panasonic as good as Nikon DSLR's? As good as D7000? Sossity Photo Cameras: Buying & Shooting 1 10-28-2010 10:47 PM
Panasonic AG-1980 as good as JVC S-VHS VCR ? ramrod Restore, Filter, Improve Quality 1 11-13-2009 07:33 PM
Toshiba (DRW2) DVD Recorder * Good or Bad Recorder Pepeart Capture, Record, Transfer 4 09-20-2006 03:12 AM
Panasonic NVSV121EBS any good? manthing Restore, Filter, Improve Quality 8 07-12-2005 06:07 PM
