04-09-2014, 04:43 PM
Zoink187 Zoink187 is offline
Hello all,
I would like advice about what filters and workflow I can use to cleanup this vhs footage. I used a JVC SR-V101US VCR for playback (with TBC/NR on, video stabilizer off, Digital R3 off, and picture control on 'edit'). I used the ATI 600USB for capture device. I capped with virtualdub (no filters) and saved to lagarith yuy2 .avi.
Here is the link:
http://wikisend.com/download/461148/SampleSgan.avi
04-09-2014, 06:23 PM
Try this script:
http://www.mediafire.com/watch/2h2cl...l2-sample2.avi
04-09-2014, 08:55 PM
Originally Posted by themaster1 View Post
Thank You. Pardon my ignorance. I downloaded it. How do I get to the script?
04-10-2014, 04:57 AM
here sorry:
http://www.mediafire.com/view/g88wag...SampleSgan.avs
The following users thank themaster1 for this useful post: Zoink187 (04-10-2014)
04-10-2014, 03:30 PM
Thanks. It seems like you have an impressive plugins folder. There are some plugins that I cannot get a hold of such as the agc.dll. That strony site is down. I can't load the script unless I have all of those plugins. Would it be possible to copy your plugin folder? Or at least send me a copy of the hragc zip?? Thanks again.
04-10-2014, 03:53 PM
you don't need all of them, agc.dll is for HDRAGC which you don't need in this script
Go here, search for hdragc, and you'll find it:
http://avisynth.nl/index.php/External_filters
04-12-2014, 11:55 PM
I'm having trouble running the script. Virtualdub keeps crashing. Any ideas?
04-13-2014, 06:17 AM
change de multithreading values ,i have a 4 cores (4 threads) cpu so that gives:
SetMemoryMax(900)
SetMTMode(3,4)
AVISource("E:\00-montage\SampleSgan.avi")
SetMTMode(4)
Problem is RemoveSpotsMC() don't work with 4 threads (only 2 according to my tests) so try :
SetMTMode(3,2)
SetMTMode(2)
Or no multithreading at all, only:
...but it's gonna take longer to process
By the way you'd need avisynth 2.6 MT (multithreads) etc..
04-13-2014, 06:25 PM
Ok. I removed the multi threading. It still crashes. I'm using avisynth 2.5 so I changed the paths. Should I just install 2.6? I'd hate to lose my current plugins. Any advice?
04-13-2014, 06:55 PM
Yes install avisynth 2.6MT if you have a multi cores cpu (most are these days) it's worth it
Take a look here and follow the instructions
http://forum.doom9.org/showthread.php?t=148782
It's also a good idea to install qtgmc (and the modded plugins) read here:
http://forum.doom9.org/showthread.php?t=156028
04-15-2014, 04:16 PM
Ok. Installed avisynth 2.6 mt. I installed the qtgmc as well and followed the directions on the doom9 forum. I replaced the old dlls with the updated ones. I tried no multi threading and also the mode for 2 cores. (because thats what I have). I still crashes. I have win7 32bit. Virtualdub still crashes. Is there another way? After several hours of time, could there even be a another way to write the script? Thanks
07-23-2014, 07:31 AM
I really wish you would attach scripts to the forum. They disappear to easy.
Better yet, show them using the forum's CODE bbcode:
Like this!
FYI: That was a sample, not a script. Those should be attached here to, or Dropboxed (and we can copy to CDN4).
avisynth, lagarith, vhs restore filter, virtualdub, virtualdub capture
VHS restore filters using Avisynth and VirtualDub - advice? Zoink187 Restore, Filter, Improve Quality 13 07-24-2014 09:38 PM
VHS post-capture VirtualDub filter advice? Zoink187 Restore, Filter, Improve Quality 1 07-23-2014 07:22 AM
VHS footage restore Advice using VirtualDub/Avisynth Zoink187 Restore, Filter, Improve Quality 0 03-28-2014 09:14 PM
Good VHS filter guides? (VirtualDub + Avisynth) premiumcapture Restore, Filter, Improve Quality 3 02-25-2014 11:24 AM
VirtualDub - advice on the filter settings deter Restore, Filter, Improve Quality 7 01-21-2010 09:54 PM
