Go Back    Forum > Digital Video > Video Project Help > Encode, Convert for streaming
07-08-2025, 03:47 PM
seeyanexttuesdsay seeyanexttuesdsay is offline
I captured a VHS tape using AmaRecTV with the HYMT codec, then imported it into VirtualDub for trimming the video length, then exported a direct stream copy. Then I reopened it in VirtualDub, used a deinterlace filter, and exported using HuffYUV multithread plugin. However both my direct stream copy and my deinterlaced second export are unable to be properly converted to other formats (I'm specifically looking to create an x264 .mp4).
I first tried Handbrake and Shutter Encoder, both of which export half of the video offset, with the other half of the video green. I also tried to Avidemux, which will export only audio with a black screen. It's been a few months since I archived a VHS, but previous everything worked fine using the same equipment and workflow, including using Handbrake to create the .mp4 file. Unfortunately I don't have the original AmaRecTV TV file as I deleted it after I exported the trimmed direct stream copy from VirtualDub.
I'm definitely a bit of an amateur in this space so I'm at a bit of a loss here. I've included an example screenshot of what's happening.
EDIT: I forgot to mention, the videos themselves play fine in MPC-HC.
07-08-2025, 04:12 PM
Aya_Rei Aya_Rei is online now
Hm, my advice is to either encode the files uses Selur's Hybrid or convert them to regular Huffyuv, not the Multi Threaded version.
I'd say try encoding with Hybrid, Handbrake kind of sucks from what I've heard
07-08-2025, 04:39 PM
I installed Hybrid and took it for a spin, but I'm still getting the same issue. It's weird to me that both VirtualDub and MPC-HC have no issues playing the files, but all of the video converter software I've tried does. Maybe an incompatibility with the FFmpeg library? I guess at this point I'm going to have to try to re-encode with regular HuffYUV and hope for the best.
If anyone else has any suggestions I'd love to hear them.
09-11-2025, 09:10 AM
mts1 mts1 is offline
Try to use the latest VirtualDub2 v2.3.0.845.
09-21-2025, 08:09 PM
I forgot to update my thread. As it turns out, for whatever reason, the problem only happens when using HuffyYUV Multithreaded and setting the colour depth to 4:2:2 YCbCr (YUY2). However, using single threaded HuffyYUV with the same colour depth produces no issues. I'm not sure why, and since single thread Huffy works just fine for my needs, I'm happy to continue using that without investigating any further.
The following users thank seeyanexttuesdsay for this useful post: brockalee (09-24-2025)
Converting from lossless to watchable video format? Okiba Capture, Record, Transfer 10 08-03-2020 07:50 AM
Issues converting SLP VHS tapes/issues viewing them on multiple players Kayleighd15 Capture, Record, Transfer 6 12-08-2019 07:48 PM
Converting VHS tapes to digital format? CodeSchlocker Capture, Record, Transfer 13 07-06-2018 12:47 AM
Converting Super 8 film to digital format? TylerDurden389 Project Planning, Workflows 6 01-09-2014 08:07 PM
Converting .flac audio files to a CD burnable format, to reburn on Mac and Windows Sossity Computers 10 06-29-2011 08:34 PM
