04-17-2025, 06:12 AM
ethanchal ethanchal is offline
Hi! First post here and have just begun my journey of trying to archive my family tapes of various sources as best as I possibly can with consumer gear. I probably have about 30 tapes in total to capture.
I've got 3 sources tape types; VHS, (JVC) VHS-C and Hi8. I'm in the UK, so everything is PAL and as far as I know SP.
So far I've purchased the following hardware:
  • Capture Card = I-O Data GV-USB2
  • TBC = Panasonic ES10
  • Computer = Windows 11, 4TB, VirtualDub
  • VHS-C adapter = Panasonic VW-TCA7E
  • VCR = ???
Regarding Hi8 I still have the original Canon UC-X10HI camcorder that was used and from reading this forum is the optimal player for capturing Hi8. I'm happy with the workflow of using the S-Video out into the ES10 and out (via AV1) into the GV-USB2.
As for VHS and VHS-C this is where I'm a little unsure on. I currently have a dusty Symphonic combo VHS player in the garage that only outputs composite over its Scart output. The VHS-C camcorder used was a Panasonic NV-S5B which I still have but now fails to playback - I've read that these playback mechanisms are generally poorly made for decent capture anyway.
So, my first question is why are S-VHS players recommended for VHS/VHS-C capture when those sources don't store the improved resolution/frequencies on the tape in the first place? Is it just the playback mechanism of these players that we benefit from? Or do camcorder VHS-C recordings still store separate Y/C regardless of tape which can only be pulled cleanly via a player with S-Video support?
And secondly, based on the answer to the above what entry to mid-tier PAL VCR player recommendations would be suitable for my mostly VHS-C collection with the Panasonic adapter? I've seen a decent JVC HC-S5955 on Facebook for £20 but I've heard that JVC like to eat VHS-C tapes for breakfast.
Much appreciated!
04-17-2025, 10:08 AM
S-VHS players are usually built in TBC and DNR and have better image processing circuitry, they have better mechanics and most importantly they bypass the composite stage which combines Y (Luma) and C (Chroma) signals into one signal in normal VHS machines degrading the chroma signal in the process and slightly reducing the luma horizontal sharpness.
04-17-2025, 10:40 AM
Welcome.
Correct, junk.
Symphonic is one of the worst brands of electronics ever made, the lowest of the low-end. We bought some of that cheap junk for our garage back in the late 80s to early 90s, and it never lasted. Even when it was new, it worked poorly.
Correct:
- better quality internals
- tape data is Y/C (s-video aka separated video), so no crosstalk noises, no massive lowering of quality like composite
- it's not about the tiny % of resolution boost from S-VHS tapes
This is not a good card. Lots of issues. It has a few overly vocal fans online, but they're never anywhere to be found when issues always arise. Or they just blame you, often with horsey attitudes.
This is not a TBC. It's a passthrough DVD recorder with a strong+crippled line TBC and non-TBC frame sync. But it always has AGC aggression, hot luma issues (especially for PAL), posterization, and some other problems. It's the "better than nothing" approach, but it's not at all a TBC. It does not prevent dropped/inserted frames, but rather bakes in. It does clean the image nicely, which is why it is suggested for anti-tearing. (There are some other items that are much better, overall, at anti-tearing, but ES10/15 type is much easier to locate.)
This is a powered Matsushita, essentially "clone" of recommended JVC C-P7U. So you're good here.
This best Hi8 camcorders have internal line TBC for playback, and the ES10 is just used for non-TBC frame sync. But again, you're degrading the quality from the tape. It looks better with the ES10, but a real TBC is needed to prevent dropped/inserted frames (and thus also maintain audio sync).
Don't screw around with Facebook, it almost never ends well. It's actually worse than eBay, and eBay junk VCRs are infamous. Those are dumping grounds, not the location of properly functioning nice gear. Get your PAL deck from VCRShop, and then resell it when done.
Yes, JVC HR series do not play nice with -C tapes, so I'd instead look at the Panasonic NV-FS88. The image quality is overall worse on Panasonic compared to JVC, though still vastly better than low-end VHS VCRs, but eating a tape is definitely worse.
pal, s-vhs, s-video, vcr, vhs-c
Does DMR-ES45V provide TBC-ish benefit? AndyO6322 Capture, Record, Transfer 2 03-19-2025 07:45 PM
Will DMR-ES10 benefit my workflow? travvytrain Project Planning, Workflows 1 02-12-2023 07:59 AM
Best player for cheap tapes? FrostBite Capture, Record, Transfer 4 10-17-2015 04:14 AM
What is the benefit of dedicated hosting? chandanshivebharti Web Hosting 3 09-14-2015 04:40 AM
Any benefit to using a D-VHS deck vs JVC S-VHS premiumcapture Capture, Record, Transfer 1 02-25-2014 06:17 PM
