01-27-2013, 06:11 PM
JLegnon JLegnon is offline
I record TV shows and movies to my computer using ATI MMC with Lord Smurfs Cartoon settings . So a 30 minute show is 700 mb , MPEG-2 .
Is there any good free software to burn these MPEG-2 videos to DVD ? I'd like to keep the quality as good as possible and fit 5 or 6 shows on a DVD .
Is DVDflick any good ?
I have corel videostudio pro x3 and did a test burning of one 30 minute show that had a file size of 700 mb . But when I loaded the video file into corel it said the video was 1.8 Gigs . I'm not sure why it said it was 1.8 Gigs when it is really only a 700 mb file , which is strange .
corel videostudio pro x3 any good for what I wanna do ?
01-27-2013, 06:22 PM
Simple DVD Creator works great for menu-less discs, http://www.digitalfaq.com/forum/dvd-...html#post18469
Corel anything is honestly not very good.
Not for authoring, at least. It's not bad at some of the other tasks.
01-27-2013, 10:11 PM
jmac698 jmac698 is offline
If you want a step up, try DVDStyler
www.dvdstyler.org
01-28-2013, 12:17 AM
naripeddi naripeddi is offline
Originally Posted by kpmedia View Post
Simple DVD Creator works great for menu-less discs,[B] http://www.digitalfaq.com/forum/dvd-...html#post18469
This is an excellent, simple program for menu-less authoring of DVDs. However, one in 50 authorings I do, I encounter problem in that this software will not generate all the files required in the Video_TS folder. In such cases, I go for another program (DVDIt V 5.0 which came free with my DVD burner).
But my main program for authoring menu-less DVD's for the movies I capture off satellite is Simple DVD Creator.
Good to see kpmedia back in action, answering questions after a brief, yet understandable gap.
regards
01-28-2013, 10:39 AM
Very Cool ! I tried it and it worked great !
I have one question , so I can only load one video file ? I didn't see an option to load multiple different video files .
01-28-2013, 08:19 PM
NeverMind , I figured out you just do one video file at a time .
01-28-2013, 09:32 PM
You can load multiple video files by clicking on ADD button. When the authored DVD is played on a DVD player, the videos will be played sequentially in the order in which you added them.
The following users thank naripeddi for this useful post: kpmedia (01-30-2013)
01-28-2013, 11:28 PM
Nice ! Thanks !
What authoring program accepts high-bitrate MPEG-2 videos? unclescoob Author, Make Menus, Slideshows, Burn 23 02-21-2012 08:22 PM
MP4 AVCHD Converter Software to MPEG? for PowerPoint presentation el1ero Encode, Convert for discs 1 12-28-2011 06:11 AM
Need a good external DVD burner to record videos Kenneth M Capture, Record, Transfer 13 04-28-2011 06:23 PM
Best MPEG-2 hardware capture device + software for Windows 7 ? lordsmurf Capture, Record, Transfer 0 03-21-2011 06:32 AM
Mpeg capture software for PVR 350 mlaviolette Capture, Record, Transfer 2 11-30-2004 01:08 PM
