01-11-2013, 02:57 PM
Green1224 Green1224 is offline
Currently I own a Tascam DA-20 mkII. I have it running into my Soundblaster Audigy 2ZS platinum using the SPDI/F input cable. Lately I've been transferring my DAT tapes to hard drive via Adobe Audition 3.0 but am having some peculiar intermittent issues.
First, certain DAT material will not transfer into the hard drive when I play them. I have SCMS off and STILL nothing seems to be transmitting from the computers speakers (all the while the sound is coming out of my DAT deck).
Intermittently, I will get a feedback sound that resembles fax machine transmittance. Now and again if I shut off the DAT deck it will go away; other times it won't. Keep in mind that when this occurs what comes out of my headphone jack on the DAT deck is the recorded sound from the DAT and NOT the feedback.
Third, a DAT tape could be effortlessly transferring with AA 3.0 and then, all of a sudden, the program will just freeze up for no apparent reason.
So, for those who are more experienced with this can you give me an idea if this is a DAT deck problem, Soundblaster sound card problem, or computer problem?
01-30-2013, 01:08 AM
JMP's Avatar
JMP JMP is offline
Former Site Staff | Computers
Firstly, welcome to the site, glad to have you.
As for your problems, the process of elimination will help to solve this I think.
-First, are you sure the speakers are working properly, and is the sound card output set properly?
-For feedback, are the cables you are using for transfer shielded and away from any power cables?
-And as for AA 3.0 freezing up, it sounds like it could be a resource issue there. How much RAM do you have in the system?
These may sound like stupid questions, but in the end it helps us narrow down what the cause is.
-JMP
- Check out my latest Editorial.
Soundcard or onboard sound for video capture? david151 Capture, Record, Transfer 23 10-20-2018 06:22 PM
Question about Adobe Premiere (masking related) unclescoob Restore, Filter, Improve Quality 5 12-28-2011 09:32 AM
8mm playback problems, tracking and audio issues admin Capture, Record, Transfer 0 10-08-2009 09:03 PM
DVD related logos/graphics padre2 Project Planning, Workflows 3 01-04-2007 02:29 AM
DVD-VR Issues Neuroslicer Encode, Convert for discs 2 09-21-2005 10:17 PM
