02-22-2013, 12:20 PM
Mejnour Mejnour is offline
I wrote that.
Edit as 720x480 or 640x480. These days, 720x480 is probably the better choice.
Final MPEG export is 352x480.
So there you go.
Dear Lord
Okay I assume that 720x480 is better these day because of 4:3 format is getting obsolete in term of HDTV and monitors?
Or may I have problem on the software side with 640x480?
In my case what I win by archiving in 720x480 instead of 640x480 if the MAIN pratical purpose is to play a MPEG-2 via a 4:3 projector?
Maybe I miss something and cannot see enough far in the future? (like when I learn that Huffyuv codec was better choice for archiving on the long run).
Right now when I encode my 720x480 AVI file to 352x480 MPEG-2, I can see via Adobe Media Encoder ouput windows that I will have black side edge because of the different ratio.
02-24-2013, 11:19 AM
More like 3:2 storage of 4:3 videos is more standard, and wasn't always in the past. It really has nothing to do with HD.
DVD = 720x480, so archiving as that means less aspect changes. It's not horrible, but avoid it when you can.
But if you're archiving as 352 MPEG, then it doesn't matter -- you'd be converting aspect either way. So 640 and 720 are both fine.
I don't see anything wrong with what you're doing.
Help with creating my VHS to DVD workflow rappy Project Planning, Workflows 1 05-09-2012 04:08 PM
Monitor calibration suggestions for video capturing/editing workflow Mejnour Project Planning, Workflows 10 02-11-2012 10:46 AM
DVD project workflow help, SLP VHS to DVD Superstar Project Planning, Workflows 4 02-27-2009 10:30 AM
What version of HUFFYUV 777sp2 Encode, Convert for discs 5 10-06-2005 05:35 AM
