Go Back    Forum > Digital Publishing / Web Sites > Website and Server Troubleshooting
03-10-2011, 05:42 PM
[NOTES]
Specify Wincache object cache in WordPress code.
From http://blogs.iis.net/ruslany/archive...cache-1-1.aspx
and mirrored at http://ruslany.net/2010/03/make-word...-wincache-1-1/
"To configure WordPress to use WinCache user cache API’s copy the following code and put it in the file named object-cache.php located at the /wp-content/ directory of your WordPress site.
<?php
Description: WinCache backend for the WP Object Cache.
Version: 0.1
URI: http://ruslany.net/
Author: Ruslan Yakushev
Install this file to wp-content/object-cache.php
Big thanks to Mark Jaquith (http://markjaquith.wordpress.com/)
whose apc-object-cache.php was used as a basis for this code.
// gracefully revert to default cache if WinCache is not installed
if ( !extension_loaded('wincache') ||
      !function_exists('wincache_ucache_get') ||
      strcmp(ini_get('wincache.ucenabled'), "1") )  {
 include_once(ABSPATH . WPINC . '/cache.php');
} else {
function wp_cache_add($key, $data, $flag = '', $expire = 0) {
  global $wp_object_cache;
  return $wp_object_cache->add($key, $data, $flag, $expire);
function wp_cache_close() {
  return true;
function wp_cache_delete($id, $flag = '') {
  return $wp_object_cache->delete($id, $flag);
function wp_cache_flush() {
  return $wp_object_cache->flush();
function wp_cache_get($id, $flag = '') {
  return $wp_object_cache->get($id, $flag);
function wp_cache_init() {
  $wp_object_cache = new WP_Object_Cache();
function wp_cache_replace($key, $data, $flag = '', $expire = 0) {
  return $wp_object_cache->replace($key, $data, $flag, $expire);
function wp_cache_set($key, $data, $flag = '', $expire = 0) {
  return $wp_object_cache->set($key, $data, $flag, $expire);
class WP_Object_Cache {
  var $global_groups = array ('users', 'userlogins', 'usermeta');
  var $cache = array ();
  function add($id, $data, $group = 'default', $expire = 0) {
    return $this->set($id, $data, $group, $expire);
  function delete($id, $group = 'default') {
    $key = $this->key($id, $group);
    $result = wincache_ucache_delete($key);
    if ( false !== $result )
      unset($this->cache[$key]);
    return $result;
  function flush() {
    wincache_ucache_clear();
    return true;
  function get($id, $group = 'default') {
     if ( isset($this->cache[$key]) )
      $value = $this->cache[$key];
    else
      $value = wincache_ucache_get($key);
    /* echo "Cache key: $key<br/>";
    echo 'Cache value:<br/>';
    var_dump($value);
    echo '<br/>'; */
    if ( NULL === $value )
      $value = false;
    $this->cache[$key] = $value;
    return $value;
  function key($key, $group) {
    global $blog_id;
    if ( empty($group) )
      $group = 'default';
    if (false !== array_search($group, $this->global_groups))
      $prefix = '';
    else
      $prefix = $blog_id . ':';
    return md5(ABSPATH . "$prefix$group:$key");
  function replace($id, $data, $group = 'default', $expire = 0) {
  function set($id, $data, $group = 'default', $expire = 0) {
    $result = wincache_ucache_set($key, $data, $expire);
      $this->cache[$key] = $data;
    return $result;
  function stats() {
    $wincache_info = wincache_ucache_info();
    echo "<p>\n";
    echo "<strong>Cache Hits:</strong> {$wincache_info['total_hit_count']}<br/>\n";
    echo "<strong>Cache Misses:</strong> {$wincache_info['total_miss_count']}<br/>\n";
    echo "</p>\n";
    if ( ! empty($this->cache) ) {
      echo "<pre>\n";
      print_r($this->cache);
      echo "</pre>\n";
  function WP_Object_Cache() {
   // Nothing here
Excellent.
Helicontech suggested gzip settings [notes] admin Website and Server Troubleshooting 0 03-10-2011 05:33 PM
Project notes, VHS restores (RK@2009) admin Project Planning, Workflows 0 11-30-2009 11:52 AM
Project notes, VHS restoration (GK@2008) admin Project Planning, Workflows 2 11-29-2009 11:05 AM
Availables blogs/CMS [NOTES] admin Web Development, Design 0 08-11-2009 12:42 AM
Research for OSx86 install, Hackintosh notes admin Computers 0 08-11-2009 12:37 AM
