What you want is more of an authoring issues, not so much Photoshop. Sure, you can create that image in PS, but I doubt authoring would do it exactly as you state. Authoring menus has limitations, especially if you're not using Scenarist or DVDSP1 to author.
Best I can say is you want to make a white background with a blue circle in Photoshop, save as the background bitmap image. Then make a button as a PSD with a transparent background. When the button is not selected, it is red. When the button is selected, it turns to the same shade of blue as the background.
That's as close as I could get you.
Buttons cannot be transparent when selected.
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
