Hello, I wasn't sure how to contact your company so am doing through your forum: I have about 50 VHS and Betamax tapes that go back over 30 years. Some of the older tapes are degraded a bit so I want to transfer to digital format. I don't need DVD's and can burn them later if needed. What I want to do is preserve mostly family events and document family history. I tried the Roxio 'Easy VHS to DVD Capture' and the quality was reduced compared to playback on TV. I suspect this is partly due to using a cheap analog to digital application, so hopefully you can do better. What format would you recommend for best quality - lossless of some sort. I assume you can do restoration when needed. Thank you
BTW. I spent a few hours looking at better equipment for VHS to digital transfer, but the cost of a good VCR, a higher-end Analog I/O Device, a TBC, plus all my time to deal with this will probably not be worth it for this number of tapes, in contrast to the cost of a commercial service.
