02-27-2016, 12:26 PM
VideoTechMan VideoTechMan is offline
Since I am getting the ViewSonic IPS monitor, it has the DVI-D port only. Of course the AIW cards both have DVI-I ports but will connect fine with the monitor.
I'd like to know what's a good DVI based KVM switch for both my XP boxes? The better ones from what I looked at are more expensive, but I don't have a problem with that if they work reliably. I also have only one set of speakers so I am not sure whether I would need to get another set of speakers or if the switch has audio capability that works properly.
I'd appreciate any help.
03-01-2016, 08:26 PM
DVI-I is analog with digital. DVI-D is digital only. So any DVI-I card should connect to DVI-D KVM or monitor without an issue.
As for suggestions, I thought I gave these to you in another thread.
I'm using the Starview 4-port DVI KVM.
- The video is perfect.
- Sometimes the shift key sticks (holding it down too long confuses the KVM), and I have to swap to another screen and back again. But it's not too often.
- From what I remember, the audio was pretty terrible, but all KVMs are. I prefer to have dedicated speakers for each system. Less wires = less noise. I've not tried KVM audio in at least 3 years now.
Aside from that, I have no idea.
03-02-2016, 04:20 AM
It wasn't directly asked; the thread in question was regarding the different video connectors on the monitors. I see that the DVI based KVM's are more expensive compared to the VGA versions.
I only have one set of dedicated speakers, so may consider another set for the second XP box. Starview, I believe its Startech as a google search refers the Starview on Startech's website.
Thanks again!
BVP4+ intermittent signal issues (c/s switch?) bilditup1 Restore, Filter, Improve Quality 13 09-22-2015 04:12 PM
To switch off a wireless router or not? Or computer? VCRs? naripeddi Computers 7 06-10-2014 04:52 PM
AG-1980 B&W / color switch weird issue volksjager Capture, Record, Transfer 2 02-18-2012 03:13 PM
Best ethernet switch that lasts, is fast & reliable Sossity Computers 1 10-06-2010 11:58 PM
TDK discs are Ritek, time to switch? admin Blank Media 0 12-01-2009 07:37 PM
