02-21-2021, 05:31 PM
lexmart lexmart is offline
I'm having issues converting VHS tapes to digital.
I'm using VIDBOX software for Mac on a MacBook Pro.
The VHS player is within my TV, a Panasonic PV-C1330W. Its a 13" Diag. Mono TV / 2-Head Mono VCR Combination. It only has (2) RCA ports, Video In and Audio In.
The converter from VIDBOX has (3) RCA ports, the yellow red and white.
When I use the software and look at the preview, I can see the volume moving up and down, but there is a blank screen where the video preview should be. Half the time when I press Record, the software doesn't start recording. The few times it has "recorded", there is no video product saved at the end. I tried all this on my friend's laptop, and we had the same exact results.
I tried restarting my computer. I'm pretty sure I installed the converter driver correctly as well. I'm guessing the issue has to do with my TV only having 2 ports? Is it worth buying a whole separate VCR player or is the software bad?
vhs vidbox
What do you think of this ATI tvPortal recording? jwillis84 Capture, Record, Transfer 8 08-09-2021 01:41 PM
Software to allow recording of copy protected VHS tapes? Ali071 Capture, Record, Transfer 2 09-10-2012 09:54 AM
Need a DVD Recorder for Recording VHS to DVD Konfusion Capture, Record, Transfer 8 04-11-2010 06:13 AM
Recording time on DVD-R? genebender Blank Media 1 02-08-2009 12:14 PM
MP3 recording question!!!!!! MOTUfan Edit Video, Audio 2 11-21-2005 05:17 PM
