07-12-2022, 03:25 PM
KhAoS182 KhAoS182 is offline
Originally Posted by latreche34 View Post
I'm pretty sure the OP is miss informed about how a frame TBC work, Cleaning a signal is not actually a technical word nor that's what's actually happening. The frame TBC does not clean the VBI signal, it replaces it completely with a new digitized one. If the signal from the tape is good, leave it alone. The frame TBC has no effect on the picture quality and should not have, Its main function is to stabilize the frame and avoid audio drift. From the OP's samples the frames are as stable as they can be and he already stated that he did not have an audio drift without the frame TBC.
Thank you very much for your clarification, reading this I think everything has become clearer to me and I am going to return the Frame TBC to the seller.
By the way, I am looking to buy a JVC S-VHS PAL, I have read the post about the recommended ones, there is one in particular that you like, to be able to buy it? Thanks.
07-12-2022, 04:05 PM
When you describe things to laymen, you can barf jabberwocky at them. You have to dumb it down, put it in terms that can be digested. Sometimes that suffices perfectly fine. Other times, you have to slowly crash-course the person into the more technical. But even then, avoid jargon when possible, in those early stages. Otherwise their eyes glaze over, and you're just blah-blah-blahing. I guess you've never taught classes? Intro info slowly.
That's not all it does.
That's not true, and is where "transparency" enters the equation. Far too many TBCs are junk, and barf noises into the signal. Some are faint, tolerable. Some outright molest the image.
No. The main goal is to strip, replace, and release timed. But even then, that's a specific version of a TBC, not frame TBC in general. In fact, "frame TBC" is a bit of a misnomer, most are actually "frame sync TBC" (and also not mere frame syncs).
I think this is false equivalency. A known bad device was added. That doesn't negate the fact that a quality TBC was probably needed, even the weaker types paired to ES10/15 that pre/partial cleaned/purified. Again, ES10/15 contains mere frame sync, it grabs and releases without timing. That "gappy" nature can create dropped frames. (This is not too far away from genlocking (aka, why it exists), but that master/slave also isn't frame sync TBC.) Internally, it tends to dupe to avoid untimed output, but it's not perfect, just a cheap chip on a DVD recorder board. The main tell is how it lacks RAM buffering needed. I find it silly how some think a single chip replaces a bank of chips found on most frame sync TBCs. It just isn't so.
But, at the end of the day, if your own tapes are working decently enough, I also agree with that last statement.
However, you'll have to carefully scrub your footage, because you cannot feel safe it's working without issue.
And then if you're doing this for anybody other than yourself, there's zero legitimate reason to not have TBCs, as from be cheap, and viewing video conversion as a "make me beer money" scheme.
The 7000s are great: 7611, 7711, 7965, some others.
07-12-2022, 07:57 PM
They should not have to alter the video and that's the major point.
I didn't say that's all what it does, I said that's what it doesn't.
Isn't that what I just said?
Anyway its all good here.
07-12-2022, 08:28 PM
Definitely should not ... but do.
I, uh ... huh?
Clearly I need more coffee. Or something.
07-24-2022, 01:40 PM
I’m trying to transfer PAL tapes with my new Panasonic NV-HS950 (TBC/3D-DNR On) with VirtualDub 1.9.11 using ATI 600 USB and Tevion Clone without Frame TBC and I have A/V sync issues. They aren’t synchronized, there’s no way and I don't know what to do anymore, I have tried many timing settings and nothing changes. I hace two PC, a very good built PC with Windows XP and my gamer PC with W10. In both I don’t get results.
Any help? Thanks.
AJA frame sync mini? waloshin Capture, Record, Transfer 28 02-12-2021 10:31 AM
BrightEye 25 capture dropout despite TBC/frame sync? dowath Capture, Record, Transfer 7 11-12-2020 03:31 PM
VHS transfer usage of TBC & frame sync combo? Dewster Project Planning, Workflows 3 10-08-2020 01:28 PM
Frame sync, Time Base Correctors Ralpphilz Restore, Filter, Improve Quality 0 02-22-2020 11:30 PM
Changed frame rate, now have audio sync problems? rand107 Encode, Convert for streaming 1 07-29-2014 08:08 AM
