04-27-2011, 09:48 PM
Tuco Tuco is offline
I was wondering if there are any ways to test whether the electrical system in your house suffers from "dirty power". I have heard of line conditioners, EMF/RFI filters, AVR, and group loop isolators. Can someone clarify what these are and which ones are ideal for capturing needs?
I know what AVR is. I have a UPS on order now ( http://www.amazon.com/gp/product/B000BMBT4I ) with AVR, but I am curious as to how these compare to Ground loop isolators, line conditioners, and UPS's with EMI/RFI filters.
Thanks!
04-28-2011, 06:25 AM
I'm sure there is, but I don't know what it is. The reason is simple: The UPS with AVR has always fixed my problems.
I do know you can pull breakers and check voltage to the line. I had somebody come over two years ago and replace a break for me, as it was causing the office to power to fluctuate. It would also trip easily.
Camera slid off my lap, onto the ground -- How to check that it is okay ? Sossity Photo Cameras: Buying & Shooting 3 12-03-2010 12:09 PM
Jittery horizontal line in middle of screen Kereellis Restore, Filter, Improve Quality 6 06-25-2010 05:32 PM
VHS to DivX ... totally confused... fatboy123 Capture, Record, Transfer 8 03-22-2010 09:59 PM
Wordpress wp-admin login loop [SOLVED] admin Website and Server Troubleshooting 0 10-08-2009 02:20 PM
Dot-dash line removal manthing Edit Video, Audio 11 06-08-2006 10:42 PM
