11-30-2020, 04:35 PM
juiceycow juiceycow is offline
After battling the infamous "TV failed to initialize the video" for 4 days and also having read countless threads here over and over, I thought I'd log my progress and solution for anyone that might get something out of it if they have the same issue.
I built a "new" WinXP SP2 box over the summer including re-capping a Soyo motherboard (SY-P4I845PEISA) and used an IDE to SD card adapter for the HDD. Made it much much easier to roll back to a clean XP install.
There was no stopping WinXP from auto installing it's own video drivers (the motherboard doesn't have on-board video), so my first attempt was to manually install the driver using the 180-V01084-100.iso (mounted using Virtual CloneDrive).
I installed/replaced the video driver manually via Device Manager (Update driver > Install from a list or specific location (Advanced) > 'Dont search. I will choose the driver to install' etc). This seemed to work ok. As mentioned elsewhere on the boards, the driver was now 6.14.10.6404.
Next installation steps were:
-WDM from :\install\WDM
-UCI (DOA?) from :\install\UCI
-Soundblaster official drivers from CD (I have a Soundblaster ZS installed)
-MMC 8.8 using the .iso setup.exe installer.
Then, after this, depending on what software I tried (Windows Movie Maker, VirtualDub, MMC TV) I got variations of the following error:
The TV Player Failed to initialize the video.
Unable to start capture video.
Video device already in use.
Error starting the device.
Most online solutions suggested another app was running and taking over the driver / overlay eg VLC Player. I couldn't find this as the problem.
In hindsight I think the issue was with the manual installing the driver / WDM steps.
I also suspected it was my Canopus AD?? and firewire card I had installed, so I removed these for the next testing. In the end they weren't the issue. Neither was the soundcard.
Fresh WinXP and I started again:
- Soundblaster card install using Audigy_SupportPack_7_0 rather than the official .iso that came with the card.
- WinXp once again auto installed the video drvers, so I uninstalled the card in device manager.
I tried 180_V01060_100.ISO video driver installer and it crashed on setup.exe "inf error. video driver not found"
I also tried the original 180-V01084-100.iso driver setup.exe (rather than installing via Device Manager), but it also crashed with the same error.
THE SOLUTION!
- For me at least.
I grabbed the 2001-2005 ATI drivers archive from The Internet Archive (I think they're all been culled from these forums anyway - the text definitely has).
This sketchy looking website also has Mediafire links to the same set with a few extra files and more years eg 1997-2001, 2006-2010.
After downloading it all I tried 6-2_xp-2k_dd_ccc_wdm_enu_30152.exe from \ATIDriverCollection\Official ATI Drivers\ATI Radeon 8000 & 9000 Series\WINXP directory. As far as I could tell it was one of the later driver versions.
It unpacked and I ran it from root of C: (it complained about directory levels or some such when ran from MyDocs).
This installer gave me the option of Display Drivers, WDM Integrated Drivers and Catalyst Control Panel).
Display and WDM installed fine; CCC would crash when trying to run it (after installing fine), so I didn't bother installing it again on my next test.
After rebooting, Windows completed installing more ATI drivers for the card, so be patient here until it finishes.
...and that was it ... All programs started the capture driver fine (Virtual dub & Win Movie Maker), and WinXP 'Add Remove Programs' control panel even had "ATI - software uninstall utility" & "ATI Display Driver".
I test installed MMC8.8 solo and also mmc-8-7-0-0.exe for the TV app and it was fine.
Other files I tested during this journey:
- wme-radeon-7-88-030430m-008946c-efg.exe (Display driver setup.exe - inf crash error)
- ATI Control panel control-panel-7-88-030430m-008946c-efg.exe installed fine.
- MMC 8.1 (mmc-8-1-0-0-dao-mdac.exe) never completed (just closed, no error - I think DAO installed).
The end! I hope this helps someone in the future.
My summary... As everyone says, video drivers and WDM have to be installed and working first before attempting the MMC etc; but it's hard to tell if WDM etc installed fine when there are no errors given during installation!
The following users thank juiceycow for this useful post: gaborHU (02-26-2021), lordsmurf (12-31-2020), Remember2Floss (02-20-2023)
12-29-2020, 05:47 PM
pcourtney pcourtney is offline
Hi Juiceycow ( nice name ) - thank you so much for outlining your method, I'm sure it will help me a lot :-)
I dug out my old Dell Dimension 8300 desktop windows XP computer from about 2003, with AGP8x slot, but when I looked inside I could see a few caps bulging so took it to my engineer friend and after a few weeks he had it all working 100%
https://www.trustedreviews.com/revie...ristmas-bundle
the graphics card inside was an old ATi Radeon 9800Pro AGP, so now everything was running OK, we swapped this out for an ATI X800 VE AIW AGP card, this I think was one of the last AGP8x cards ATI made around May 2005
https://www.techpowerup.com/gpu-spec...-x800-ve.c1912
its not listed on post #6 - under AGP Theatre 200 cards, but maybe it should be
http://www.digitalfaq.com/forum/vide...der-hacks.html
AGP: (Theatre 200 chipset)
ATI All-in-Wonder 9000
ATI All-in-Wonder 9200
ATI All-in-Wonder 9600 / AIW 9600 XT / AIW 9600 Pro
All-in-Wonder 9700 Pro
All-in-Wonder 9800 Pro
ATI All-In-Wonder 2006 Edition AGP8x
the only thing holding things up here is a Sony TBC that will sit in the middle of my workflow between the ATI X800 and my Sony VHS tape player, I should have it back soon, but the guy local to me that services these old betacam machines has not been too well
have about 200 VHS and about 300 V8 tapes to convert next year, so it will be nice to do it right
Originally Posted by NJRoadfan View Post
Its tough finding older drivers for these cards, particularly the WDM capture driver kits. People seem to archive the main Catalyst packs, but the rest seem to be a 2nd thought. I'm working on trying to get my AIW X800 PCIe capturing video under XP 64-bit. The latest drivers on AMD's site are broken for video capture, so I'm hoping an older revision works. Finding said older revisions has been a challenge to say the least!
maybe this will work
https://www.amd-drivers.com/download...sXP-64bit.html
AMD/ATI drivers for Radeon X800 and Windows XP 64bit
I made a nice discovery with my new ATI AIW X800 XT PCIe. It captures audio directly from the Theater 200 chip, that's right, no need for any sound card. The machine didn't even have any sound card drivers installed! This is great news as I won't have to worry about audio drifting out of sync with the video during capture, am curious if this applies to the AIW X800 AGP and 2006 editions.
I have an AIW X800 VE AGP8x card ( All in Wonder ) - one of the very last AGP cards made in 2005, it had both DVI and VGA output on the external plate, and I can confirm that it works without any sound cards or onboard audio needed
Using drivers dated 14th April 2005 - 2005-04-14 6.14.10.6534 DVD Title 180-V01106-100
The DVI output from the X800 goes into my B&O Beovision 26" TV, as does the stereo sound output from the X800 into the Phono RCA plugs on the TV
I bought my X800 VE on the back of this UK review in 2005, I could not get the X800 XT AGP at the time
https://www.hexus.net/tech/reviews/g...onder-x800-xt/
The following users thank pcourtney for this useful post: archivarious (01-15-2021), lordsmurf (12-31-2020)
  #203
12-31-2020, 12:55 AM
Look again.
Do you have the original install CD that came with it? If so, I want to add it to our archive here. I've been ripping and sorting my discs lately, and I have quit a few to add to this thread (and make some other threads for other cards).
12-31-2020, 06:31 AM
thank you for adding my card
this is the DVD I have attached
what is your favourite place for huge uploads LS ??
and I will get it uploaded in the New year
File Type: jpg ATI Catalyst 100 DVD 180 V01106 100.jpg (71.7 KB, 23 downloads)
01-15-2021, 07:37 AM
archivarious archivarious is offline
Would an 9800 SE be a valid Theatre 200 option? It's not in the list currently.
01-15-2021, 07:49 AM
google it and you would know
https://forum.videohelp.com/threads/...vs-AIW-9800-SE
  #207
01-15-2021, 07:57 AM
Thanks for flying in here for the swift response. I've been looking around for an hour, didn't find this one. Then it seems the 9800 SE just as fine as the ones on the list? Thanks
02-28-2021, 05:25 PM
Just a quick follow up to my post above.
- I failed to mention that my card is an AIW Radeon 9000 Pro
- The captured video had issues with stuttering when it came to deinterlacing and doubling the framerate (50fps) (I outlined the issue here)
Long story short I reinstalled the card using the drivers from the AMD website https://www.amd.com/en/support/graph...onder-9000-pro and a fresh base of WinXP SP2.
I just install the essential drivers from the two downloads:
1. Catalyst Software Suite 6.11:
Display Driver & WDM drivers.
I didn't install Catalyst Control Center - It failed, plus I don't need it anyway.
2. DAO/MDAC package (Windows Media Encoder 9, DAO/MDAC.)
I still use Audigy Support Pack 7 for my Soundblaster Audigy 2.
I capture in VirtualDub1, so there is no need for MMC and all it's garbage IMHO (after reading all these posts I thought it was a necessity).
The following users thank juiceycow for this useful post: archivarious (02-28-2021), Master Tape (11-14-2022), Remember2Floss (02-20-2023)
  #209
04-25-2021, 04:20 PM
pewu pewu is offline
I got myself a nice NV-FS200 (PAL) to digitize some old family tapes, also managed to acquire a DMR-ES10 (PAL) very cheap in non-working condition and recapped the PSU to make it work again. As I read on the forum, I shouldn't use DMR-ES10 if the TBC on the VCR is enabled, so I'm going to stick with only VCR (TBC on) and try ES10 if I encounter any problematic tapes.
The main question though is the capture card in the chain. I have an old Leadtek TV2000XP Expert lying around, but I can also pretty cheaply get an ATI VIVO card - seems to be a Sapphire Radeon 9200. It is not the recommended AIW thing, though it appears to have Theater chip as well. Bonus points for regular S-Video in without any breakout cables - all other cards sold in my country are without any cabling whatsoever. Just wanted to confirm - are VIVO cards with Theatre chip provide a decent quality captures, as the AIW cards do? I'm attaching somewhat low res pics from the auction site, Rage Theater chip is quite visible, though. It's no Theater 200, but again, from what I learned here, there isn't much difference between the two.
05-08-2021, 02:55 PM
The_Outsider The_Outsider is offline
Is this disk of any use/interest?
08-06-2021, 03:34 AM
orlando_furioso orlando_furioso is offline
Longtime lurker, first time poster. Let me know if this needs it's own thread.
Thanks to all the hard work and insights on here (truly incredible!), I'm finally building up a workflow to transfer some old Video 8 recordings and movies we made on VHS decades ago. I'll be looking to VirtualDub these in some flavor of HuffYUV. Looking for some guidance on installing the correct drivers (in the correct order)
VHS Panasonic AG1980
(TBC is still TBD, but watching for lordsmurf to get more)
Dell Dimension 4550 (P4 2.40GHz 1.00GB of RAM) for AGP
Win XP Professional SP2
ATI AIW 9000 AGP
I have the 180-V01084-100.iso burned to a disk and that seems like it's easy, but then I read a post that scared me into thinking I'd have to (somehow) get XP SP1 installed, install this from this image and then upgrade back to SP2? That seems... convoluted and as it was I had a fair bit of difficulty getting this rig talking to Win XP SP2. This post recommends using a 180-G01445-200 image (and implies the "-200" may suggest it's tested to work with SP2 flavors.) This seems like the way to go, but I wanted to pick your brains before I get some weird wrong-driver installed and have to start over.
08-06-2021, 04:09 AM
It's close enough, still on topic.
ATI AIW 9000 AGP
All fine.
PM me.
It's nutty nonsense. SP2 is fine, SP1 rollback not needed.
No. The numbers from ATI are sometimes seemingly random. I wish it were that simple.
Go for it.
- The worst that can happen is you have to reinstall the OS. The computer won't catch fire, or zap you into Tron.
- The best that can happen is that everything goes as planed, the card works perfectly, and you'll be happily capturing (after you get a TBC).
There's so much ATI AIW info, I sometimes forget exact details. Are you saying that the ATI AIW 9000 AGP had two driver CD versions? That seems unlikely. In most cases, every card had only one setup/install CD. Yes, many cards will be interchangeable with CDs. But you ideally want to pair a 9000-era card with the installer. (It's the 7000 series cards that predates Catalyst and MMC8 that generally need newer install files, hence the downloads in this thread. And I do have many more ISO files, just not uploaded everything yet, got crazy sidetracked in 2020, still not fully caught up.)
12-10-2021, 12:02 AM
servese43 servese43 is offline
Here's an image of the 180_V01111_100 Catalyst disc. Don't know what card it's good for, I originally bought it for my x800 and it didn't work. Thought I'd just post it here so my $20 wasn't entirely spent in vain.
12-15-2021, 08:08 PM
Attached is the 180_V01107_100 Catalyst Disc that came with the circa 2005 NTSC 256MB ATI AIW X800XL PCIe card.
The following users thank NJRoadfan for this useful post: servese43 (12-15-2021)
  #215
01-22-2022, 06:43 AM
enois enois is offline
I can confirm that CD is identical for AIW X800 128 EU PCI-e.
02-24-2022, 09:22 PM
Dan316 Dan316 is offline
Unconfirmed User
Hi-I bought an ATI 8500 AGP card (see Attached pic)but it did not have an install CD. I installed it in a Dell Dimension 8100 with WIN XP Pro and it just installed itself and works fine as a video card. I tried installing the ATI All-In-Wonder Setup files from the earlier posts(181-G01116-110) iso burnt on a CD but it doesn't even try to install. I manually installed the ATI info exe file. I then installed the MMC 7.5 but I don't know how to get the control panel for capture since it does not appear to be installed at all. I didn't install the DVD player and the TV software. I have the Library and the TV tabs on the desktop but I don't see the actual control panel to capture video. Any help would be appreciated. Thanks.
05-12-2022, 05:27 PM
Zerowalker Zerowalker is offline
Originally Posted by Zerowalker View Post
It doesn't allow over 32mb, mine is 310mb.
EDIT:
Oh guess you want me to split it up?
Damn hate stuff like that.
Will do like this, i will upload it to my google drive, when you got it, i will remove it from there as it takes to much space
Here: https://drive.google.com/file/d/0B_U...it?usp=sharing
Seems there's been a security update which messed up the previous link.
So instead of using that use this one:
https://drive.google.com/file/d/0B_U...zl3sQ2lBII_Qrg
05-31-2022, 11:16 PM
rightonprime rightonprime is offline
hey guys - i just bought an ati 600 usb and want to disable macrovision via editing the driver/registry. anyone have success doing this?
08-01-2022, 08:10 PM
altairst8te1974 altairst8te1974 is offline
I am here because of the blasted code-10 error!
I am a long-term user but only just regged onto the forum. My cards have been around since 2004 and I will never sell them! Even the dead ones lol.
I have a niggly problem which is driving me mad, one of the cards has code-10 but will go away when I swap the card to another one that is exactly the same, part number, model, pcb the lot!
I have more of the same card but when you have more than one of these cards and they all came from the same source (ATI Canada) you know something is amiss when just one of these cards refuses to clear code-10 no matter what you do!
Oh and BTW! I still have two retail boxed 9800 All in wonder cards. I have everything including the driver cd's if anyone is interested in me imaging them?
08-02-2022, 06:43 AM
Hardware fault is likely.
Running 32/64-bit HuffYUV codecs concurrently in Windows 7 Ultimate 64-bit vtak4 Edit Video, Audio 2 08-27-2011 07:29 PM
Pioneer DVR-103 / DVR-A03 firmware hacks [archived] lordsmurf Blank Media 1 02-16-2010 05:19 AM
Various ATI MMC registry hacks admin Capture, Record, Transfer 0 02-15-2005 09:23 AM
ATI MMC registry volume hacks? lordsmurf Capture, Record, Transfer 0 02-15-2005 08:17 AM
What are the best codecs to install ? jrnyhead Videography: Cameras, TVs and Players 1 04-28-2004 03:40 AM
