11-14-2022, 10:58 PM
Originally Posted by juiceycow
Just a quick follow up to my post above.
- I failed to mention that my card is an AIW Radeon 9000 Pro
- The captured video had issues with stuttering when it came to deinterlacing and doubling the framerate (50fps) ( I outlined the issue here)
Long story short I reinstalled the card using the drivers from the AMD website https://www.amd.com/en/support/graph...onder-9000-pro and a fresh base of WinXP SP2.
I just install the essential drivers from the two downloads:
1. Catalyst Software Suite 6.11:
Display Driver & WDM drivers.
I didn't install Catalyst Control Center - It failed, plus I don't need it anyway.
2. DAO/MDAC package (Windows Media Encoder 9, DAO/MDAC.)
I still use Audigy Support Pack 7 for my Soundblaster Audigy 2.
I capture in VirtualDub1, so there is no need for MMC and all it's garbage IMHO (after reading all these posts I thought it was a necessity).
Thank you so much! I've literally spent months trying to get this card to work, and those two drivers did the trick. I also have the same card as you. Wish i had seen this post sooner, would've saved me alot of stress and hassle lol.
11-15-2022, 10:49 AM
I need to find somewhere to upload my set of drivers I have been using since 2004 onwards with every single all in wonder card I have!
I call them my "sweetspot" drivers. They have never let me down. I copied/cloned them everywhere in my stash of stuff.
I need to detail exactly what I have, will do that promptly.
The following users thank altairst8te1974 for this useful post:
Remember2Floss (02-20-2023)
11-22-2022, 06:47 PM
I noticed in this post here, the AIW 9700 Pro appears to be PAL. Does this mean it's the only one that can capture PAL media?
08-15-2023, 11:37 AM
On Win 10 64 bit, got ATI TV Wonder VE (?) I got decades ago at a Goodwill. Been trying for years to get it to work. Only time I ever got it working was under Ubuntu years ago. Will any of the drivers etc on this thread help/work?
looks like attached image
Reason: wrong model
09-20-2023, 02:39 AM
By request, adding both ISO (drivers disc) for the ATI AIW USB.
- Download 180_V01089_100 first, try it.
- If it fails, only then should you attempt to get the 180_V01100_200 image.
angelo7XAU (09-30-2023)
02-12-2024, 01:34 PM
What is the current best method to seting up my recently acquired ATI TV Wondwer 600 usb dongle on my Windows 7?
I have Vdub set up and Huffy integrated successfully, i think.
Do i need to make a cd of the iso of the software?
I have muddled my way through this forum looking for an answer and the one i think i need to implement are from very old posts.
Do I need Crossbar Thingy for this capture device ?
Please help me figure out the most recent correct method to utilize this dongle?
After that I will hook everything up and do some testing.
THANKS
02-16-2024, 11:06 PM
Which drivers should be used for the AIW USB?
02-17-2024, 11:39 AM
That’s a great question.
02-17-2024, 11:43 PM
Post #225, from 09-20-2023, just 2-3 posts earlier, has the ISO for the USB.
Use either of them. Just variants uploaded for posterity.
Download ISO, mount ISO (MagicISO, MagicDisc).
Setup/install drivers. Not CMC.
Probably reboot.
Open VirtualDub, card should be there.
The 600 USB default audio levels are too high. It needs a registry hack, to adjust values from 100% (256) to 50% (128), I forget the db value offhand. Audio should always be captured at 50-66% of the system max, to avoid too low (insufficient gain, raising noise floor), or too loud/high (distortion). That quick proceed is outlined here.
Not old. Evergreen. Has not changed, will not change.
No.
03-02-2024, 05:13 PM
Is the AIW 9000 Pro low profile acceptable? The purple input box is easy to find but what about for video output, that weird square?
https://i.ebayimg.com/images/g/8hoAA...inq/s-l500.jpg
Is it a useless card without the dongle that gives you DVI/VGA output?
