05-14-2012, 11:24 AM
sesselmarder sesselmarder is offline
Hi all,
I am about to start to convert my old VHS tapes to DVD (or maybe AVI, not sure yet). I read on this webpage that it is essential to use a very good VHS player with TBC. Several VHS players are suggested, like the JVC 9600+, JVC 7600+, etc. But what about D-VHS players? Would they make any difference in terms of picture quality? I have a chance of buying the JVC HM-DR10000. Does anyone know if this is a good machine?
Thanks for your inputs...
Dan
05-14-2012, 12:20 PM
the the JVC HM-DH40000U & HM-DH5U, the Marantz MV-8300 and Mitsubishi HS-HD2000U are good DVHS players
AVOID the JVC HM-DH30000U - it is crap
i'm not familiar with the JVC HM-DR10000
05-25-2012, 11:26 PM
The D-VHS and higher-end S-VHS players are essentially the same in most ways.
The 40000U is the most liked model, of all the ones available.
Some of this may already be discussed at length on the VCR page: http://www.digitalfaq.com/forum/vide...ing-guide.html
Also search the forum: http://www.digitalFAQ.com/forum/search.php -- I know there's a lot of discussion, going back several years.
There's also this post about the 10000: http://www.digitalfaq.com/forum/vide...dr10000ek.html
Best method to convert VHS tape to DVD, hard drive? fish1534 Project Planning, Workflows 2 02-14-2021 08:09 AM
Capture card and setup advice, what's best to convert 80 VHS tapes ? volksjager Capture, Record, Transfer 14 02-20-2012 09:28 PM
Beta home tapes to DVD? How to Convert Betamax to digital? rocko Project Planning, Workflows 4 07-14-2011 11:23 PM
Have some .mpg and .mpeg files, how do I convert to dvd player format? admin Encode, Convert for discs 0 06-27-2010 04:14 PM
Is this DVD recorder and SVHS player good for capturing VHS/8mm tapes? ramrod Capture, Record, Transfer 1 10-12-2009 10:54 PM
