02-26-2014, 08:47 PM
Zoink187 Zoink187 is offline
Hello Again,
I am desperately trying to install the huffyuv codec to be used on virtualdub for lossless avi capture on my computer. I have seen several forums for the 64bit versions of windows 7 but not for 32bit. I do not have the folder "wow64"(I know that's not the exact path) on my drive when I use the command prompt. Is there a step by step I can follow to get this successfully installed? I have the most recent version of virtualdub. Thanks
02-26-2014, 09:39 PM
I have three different 64 bit windows setups (PC, Intel NUC, and Macbook Pro) and could not get Huffy on any of them with any of the guides. I ended up throwing in the towel and went with Lagarith. If there is a solution, I am interested as well.
02-26-2014, 09:56 PM
This this one -- see attached.
Unzip it.
Right-click the file huffyuv.inf and install. Does that work? The 64-bit version didn't exist when the guide was created some years back.
02-27-2014, 05:59 AM
Ok. I'll give it a shot! I'm replying on my phone. Is this an auto installer once I unzip it?
02-27-2014, 06:00 AM
No. It's not an installer at all. Re-read my last post.
02-27-2014, 06:22 PM
Excellent!!!! Thanks!!!!
02-27-2014, 06:45 PM
No luck on my part Sticking to Lagarith for the time being.
huffyuv, virtualdub capture, windows 7 32 bit
Cannot install HuffYUV on Windows 64-bit Vista or Win 7 [solved] phyxius Encode, Convert for discs 34 10-05-2023 11:47 PM
ATI 600 USB won't install on Windows 7 Core i7 System AndyO6322 Capture, Record, Transfer 20 10-21-2019 01:13 PM
Computer will not reboot after installing Windows updates? Superstar Computers 3 11-11-2012 06:53 AM
Running 32/64-bit HuffYUV codecs concurrently in Windows 7 Ultimate 64-bit vtak4 Edit Video, Audio 2 08-27-2011 07:29 PM
Transfer old system to new system couldbe Computers 1 03-22-2004 11:00 PM
