07-22-2016, 10:29 PM
waloshin waloshin is offline
Bought a Sony SL-HF900 with a tape eject problem for $40 ... The couple said it worked great until it stopped ejecting tapes. Here is a video I took of it turning on and me hitting the eject button. Also when turned on should their be a menu like a VHS on screen?
https://youtu.be/5MQQdRhQ5o0
07-22-2016, 11:26 PM
The gear looks to be mechanically okay, but I could be wrong.
07-23-2016, 08:55 AM
http://i.imgur.com/DGirWsH.jpg
02-18-2020, 07:39 PM
Betamax Betamax is offline
To fix this loading problem I have replaced one or two of the loading gears on the right side of the tape loading mechanism in the SL-HF900 and one of my other models. Each time it had one or more broken teeth. I need to fix that problem in my EDV-9500. Make sure you consult the repair manual to get the gears installed back in the correct alignment!! The parts I used were 3-684-163-01 (gear, driving arm)/x-3684-123-1(gear assy, driving) and might also fit SL-HF600/900/1000 and possibly EDV-9500. Check your shop manual as there could have been revisions.
Sony Betamax SL-HF900 cuts power? wesofthedead Video Hardware Repair 5 03-01-2021 06:05 PM
Sony SL-HF900 audio cutting out in HiFi mode? wkrbee Video Hardware Repair 4 06-30-2019 10:10 AM
SL-HF900 ejects tape right after insert emamid Video Hardware Repair 9 04-04-2019 03:32 PM
Samsung SV-5000W world vcr tape won't eject? waloshin Video Hardware Repair 1 09-30-2018 04:32 PM
JVC HR-S6900U turns off after tape insert or eject? Y4BB Video Hardware Repair 6 08-14-2018 10:06 AM
