06-28-2019, 10:26 PM
Duder_me Duder_me is offline
Originally Posted by cbehr91 View Post
Re: the herringbone noise. Are you using the OEM Sony AC adpater for the camera? I had a generic China Pride brand one for a Digital8 camera that put out herringbone noise on S-Video out. Chokes did not help but it doesn't hurt to try. Spending the extra bucks for a genuine Sony adapter cleared up the issue for me.
Yes, it's the OEM Sony adapter, however out of convenience I used the one that came with my original camcorder. The one that came with the capturing camcorder from eBay is the exact same model. Does it make a difference if one is more used than the other?
06-29-2019, 06:40 AM
I would just test the other one to see. Usage may have an impact, but it may as well be a bad component somewhere. It's the kind of issue that will only be visible on S-Video since the Y/C filter may filter this out so someone testing the camera with a TV using a composite cable may not notice it.
The general approach is to try to replace each element in the capture chain until you find the part causing problems.
I've also had an issue with a bad replacement supply. It gave a different visual issue though.
Two VirtualDub questions: cropping artifact, file splitting start/end points ashworth080142 Restore, Filter, Improve Quality 5 07-23-2014 07:05 AM
Convert NTSC to PAL and back to NTSC ? admin Capture, Record, Transfer 0 07-24-2010 08:29 PM
Ask Questions in Forums, not PMs admin General Discussion 0 01-07-2009 02:49 AM
Blu-Ray questions.. SavageAmusement Blank Media 2 07-18-2006 07:01 PM
Hd questions manthing Videography: Cameras, TVs and Players 2 03-12-2006 11:12 PM
