06-05-2005, 09:46 PM
d.smyth d.smyth is offline
how do you do it,
is there softwere that will do it ,
i have tryd extract 480x480 MPEG-2 and re-encode it to 352x480 with mpeg-vcr but the picture gos bad.
can anyone help.
06-05-2005, 09:50 PM
Use this method to extract the M2F2 MPEG video:
http://www.digitalfaq.com/dvdguides/...d/vcdtodvd.htm
Then re-encode those MPEG to DVD spec files:
http://www.digitalfaq.com/dvdguides/...nc/tmpgenc.htm
Then author a new DVD.
06-06-2005, 03:58 PM
markatisu markatisu is offline
yeah dont use mpeg vcr to re-encode, use tmpg or procoder
The quality should remain almost exactly in tact because you are only resizing a portion of it and not by much so it should look almost identical when done
06-08-2005, 04:33 AM
MagnificentMarcus MagnificentMarcus is offline
Ok, I'm lost! What's new? Could you please explain in a little more detail. Is all you need to do is use the second step that LS recommended? This is not a free program correct?
Help with converting AC3 to AIFF on Mac via Email or PM Edit Video, Audio 1 03-30-2010 04:47 PM
Converting H.264 TS to MPEG-2 files? mlaviolette Encode, Convert for discs 5 03-22-2010 07:09 PM
How to convert MV4 to MP4 video files ? gatch72 Encode, Convert for streaming 1 02-20-2009 02:39 PM
Digital cable = the new svcd format Tranzor Videography: Cameras, TVs and Players 5 07-06-2008 05:19 PM
Converting RCA to y/c and back Tom_n_Jonna Capture, Record, Transfer 2 10-12-2005 11:23 PM
