09-30-2013, 11:08 PM
via Email or PM via Email or PM is offline
Hi lordsmurf! I'm a fan of reading various articles on your digitalfaq forum and I was hoping you could help me out on this audio repair problem that I'm hitting the wall with. So, basically I bought this German bluray of a bollywood movie which was remastered by Rapid Eye Movies in Germany.
It contains two dts-hd ma audio tracks, hindi and german. The german audio track sounds like it was mastered for a new movie yet the hindi audio sounds like it's coming out of a tin can. The center channel of the hindi audio in particular sounds really bad.
I was actually thinking about swapping the center channel with the german audio so that I wouldn't have to touch the other channels at all. That raises another issue with the parts of the movie in which the center channel's dialogue echoes permeate through to the other side channels for effect.
So, here's the thread on doom9 which I posted about two weeks ago and the solution posted by raffriff42 worked a bit but still didn't provide the dramatic change I was hoping for.
My question is, what do you recommend for fixing this particular audio and would you recommend replacing the center channel of the German track with the center channel of the Hindi audio track and dealing with the "echo" portions by using all the channels of the hindi audio for those specific parts?
Thanks in advance and hope to hear from you soon!
- dansrfe
edit: Forgot to add the doom9 link! http://forum.doom9.org/showthread.php?t=168375
09-30-2013, 11:13 PM
I'm not yet convinced that simply swapping out audio channels is going to fix this.
For sure, the Hindi audio sounds as if it's damaged beyond repair, likely the victim of over-filtering by a novice editor. Once audio has been digitally over-process, is extremely difficult to impossible to fix. Too much audio information is thrown away in the process. Same for over-compression -- same issue.
Acquiring a high-quality audio track for the Hinid would be more ideal.
HDMI Audio: Pass though TV or Direct to Sound Bar? fortunec00kie Videography: Cameras, TVs and Players 1 01-30-2013 04:00 AM
Parasite sound (audio noise) during capture? monks19 Capture, Record, Transfer 4 05-08-2012 03:54 AM
Audio clean-up options, Sound Forge SSStudio Restore, Filter, Improve Quality 9 12-15-2009 09:10 PM
Sound Card / Digital Audio Cables CaZeek Capture, Record, Transfer 3 12-13-2004 10:58 AM
Help with ATI sound: audio is noticeably lower volume in capture buckcrisp Capture, Record, Transfer 4 05-04-2004 01:47 AM
