10-21-2020, 03:54 PM
anolegang anolegang is offline
Hi all, I’m hoping to get some help with understanding where I can go from here to make my VHS capture look better. This is for a project where I’m digitizing my collection of Japanese VHS tapes, using a JVC SR-VS30 (using the internal TBC), with optionally a ES15 if the video seems like it needs it (didn’t use it on this tape), going into a ATI 600 USB capture card over s-video and then saved in HuffyUV format.
My goal is to have a “good” looking final output that I can archive / share in an easily consumable format.
I’m having some trouble with the posted video (a compilation of clips from throughout the tape), for which I used the following Virtualdub filters:
1. Deinterlace (yadif with double frame rate)
2. Crop edges
3. MSU Denoiser
4. Camcorder color denoise
5. MSU Smart Sharpen (borders only)
6. resize to 640x480
7. interpolate frame rate to 60fps
I also tried Neat Video, which cleaned up some more noise but also destroyed a lot of detail. I’m not sure where to go from here and there are still some issues that are nagging me, such as the yellow banding which the CCD filter helped with, but didn’t entirely eliminate. The tape might just be too old since I tried other tapes and the banding isn’t present on them.
I don’t think there are issues in my capture setup, so improvements would be on the processing side. Are there other Virtualdub filters I could try to clean things up?
Thank you!
WARNING: The attached clips are NSFW, my apologies if this violates a rule (I couldn't find any related to this). If it does, let me know and I can remove them. They’re also a little more compressed than I’d like, to fit into the upload file size limit.
10-21-2020, 04:50 PM
traal traal is offline
"Deinterlace" on that video results in judder. So does "IVTC", so I can't tell if the original source was video or film.
2. Crop edges
Don't crop. Mask.
Resizing reduces sharpness, then you have to sharpen to fix it. Instead, at the very end of your process, just tell the container (.mkv or .mp4) that the aspect ratio is 4:3.
You could try repacking the tape (fast forward all the way to the end, then rewind).
Also, it looks like the histogram wasn't set correctly when capturing. The blown whites and crushed blacks will limit your ability to restore the video.
10-21-2020, 05:22 PM
From what I can tell some scenes have judder (such as the second one) and some don't, so I'm not sure what's going on there. Not sure how to fix in this case.
Thanks, this makes sense.
Ah ha! This is one of those steps that I totally missed, so it sounds like I'll have to recapture with that in mind at the very least. Thank you!
How to improve quality of CED Videodisc capture? WestRGB Restore, Filter, Improve Quality 10 10-22-2020 01:04 PM
VHS home videos post-processing, green/magenta artifacts? xabba Restore, Filter, Improve Quality 2 10-12-2020 09:25 AM
How Critical is GPU Support in Post Capture Work? colony Restore, Filter, Improve Quality 1 05-04-2019 11:56 AM
Post processing on analog capture to match a reference video lollo2 Restore, Filter, Improve Quality 2 09-16-2017 02:45 AM
Request advice for filters/post processing Vhs capture from sample threepeak Capture, Record, Transfer 0 07-22-2016 09:20 PM
