05-05-2022, 02:11 AM
Thank you for the reply so fast.
I am assuming the settings you're using are the ones for your program and not Hybrid correct?
05-05-2022, 02:49 AM
It's actually built in the capture device and are part of the proc amp after the video has been converted to digital, A link to those menu pages.
05-09-2022, 11:16 AM
Interesting.
Also I wanted to ask when you do your video conversion down and then up for 720x480 --> 704x480 --> 1440x1080
Are you just using the normal resize or are you using the resize tool inside of AVIsynth or Vapoursynth? Could you possibly post your settings so I could see exactly what you're doing?
Thank you!
05-09-2022, 12:04 PM
720x480 -> De-interlace -> Crop to active video area -> Upscale to 1440x1080 all in one step using multiscript avspmod frame visualizer.
AviSource("C:\Users\User\Desktop\graduation.avi")
AssumeTFF()
QTGMC(Preset="Fast")
Crop(X1, Y1, X2, Y2)
LanczosResize(1440, 1080)
05-09-2022, 06:42 PM
AssumeTFF()
So that would bring it down to 704x528 and upscale to 1440, 1080 all at once?
05-09-2022, 07:52 PM
No, Where did you come up with 528?
05-11-2022, 02:47 PM
My mistake. I meant 704x480. As you mentioned in a past post on this thread bringing it down to 704 before upscaling to 1440.
05-11-2022, 04:18 PM
You can bring it down to any resolution as long as you crop in a 704:480 ratio so you don't alter the frame's geometry, Meaning if you have to crop to 698 horizontally, 698x480/704 = 476, the new resolution will be 698x476, resize this to 1440x1080.
06-28-2022, 08:24 AM
AssumeTFF()
I also found this thread super helpful. Just had one question about cropping the video.
Example:
I need to crop all sides to get rid of the overscan...
Right: 8
Left: 8
Bottom: 8
Top: 2
This would bring the resolution to 704x470
Do you take any additional steps if you need to crop the overscan on the top and/or bottom?
Reason: typo
06-28-2022, 09:30 AM
704x470 is a wrong aspect ratio, I don't understand your question, you've already cropped the image.
06-28-2022, 09:36 AM
How do you get rid of the overscan on the top and bottom while keeping the correct aspect ratio??
06-28-2022, 09:51 AM
AssumeTFF()
# Crop Right=8, Top=2, Left=8, Bottom=8; result=704x470
Crop(8, 2, -8, -8)
# Center the 704x470 video in a 704x480 frame to restore the 10:11 PAR
AddBorders(0,5,0,5)
# Upscale to square pixels
This adds black borders at the top and bottom in order to keep the correct PAR.
06-28-2022, 10:15 AM
By cropping proportionally or masking off.
06-29-2022, 10:03 AM
What codec/file format do you export to?
Thanks for the info!
06-29-2022, 10:49 AM
06-29-2022, 09:40 PM
Once you have the upscaled lossless avi, what application or script do you use to encode to MP4? And would you mind sharing your settings/script?
I’m using hybrid, but don’t like the results using the settings I’ve seen on this forum and others. After doing some digging, I figured out settings in hybrid that make the MP4 look pretty much identical to the lossless avi, but the encoding is taking way to long. So I’m searching and hoping I can find a way to encode a little faster while keeping the same quality.
06-30-2022, 12:15 AM
My encoding is about 5-10 frames a second, not what you are looking for.
Thread |
Upscaling VHS before or after capture, which is best?
BIGMEDIADINO |
3 |
10-23-2020 12:51 PM |
NTSC vs. NTSC-J IRE black levels? (capturing Japanese VHS tapes)
Wingzrow |
7 |
08-30-2020 09:49 AM |
VHS upscaling to HD?
waloshin |
5 |
06-10-2019 03:16 PM |
Faroudja video processors for upscaling video transfers?
MelnickStudios |
2 |
03-23-2017 03:15 PM |
Wanted to buy Blu-ray player for upscaling VHS
Giana |
2 |
01-08-2013 11:59 PM |
