01-24-2024, 08:53 AM
Hi! First post written here but many read, up till now
I used to work with FCP 10 years ago on Mac and now I am trying to understand Avisynth+ and Premiere pro on Win10 for a project of restoring, editing (noise, color, few titles, audio editing) and archiving old VHS theater shows. This short example was captured from JVC HR-S9850 via IOdata gvUSB2, Amarectv-UTvideo ULY2 loosless. Final file will be MP4 and probably copy of it in ULY2 for a possible future needs.
Most of VHSs are in better quality then this one but I have to do my best on it and I am stuck.
Those horizontal lines and blurry faces are ugly but I don't know how to address them if possible. It seems to me like an copy of copy artifacts but maybe I am wrong, my knowledge of Avisynth+ and filters is very limited (music is my field).. Can someone with better experience give some advice on it?
Working on PAL, 720x576
I tried to do something with this script :
SetFilterMTMode ("QTGMC", 2)
FFmpegSource2("GRode.avi", atrack=1)
AssumeTFF()
QTGMC(Preset="Super Fast", Sharpness=1.0, EdiThreads=2)
Lanczos4Resize(720,576)
Crop(0,2, 0, -12)
AddBorders(0,2, 0,12)
Prefetch(4)
Thank you all!
Svrle
01-24-2024, 02:20 PM
It's more about the noise if you ask me, that's a task NeatVideo V5 will like
01-24-2024, 06:39 PM
Thank you themaster1! I downloaded the Neatvideo demo few days ago and I am trying my best but it is hard to take "the noise" and leave the faces recognizable in this thick capture case. No much detail- free space to set the profile correctly. Pls check the attached video example with this script and neatvideo.
FFmpegSource2("GRode.avi")
AssumeTFF()
#ChromaShiftSP(X=-2, Y=-2)
QTGMC(Preset="Draft", Sharpness=1.0, EdiThreads=2)
Crop(14,14, -14, -14)
AddBorders(14,14,14,14)
Prefetch(4)
Color advice? Sharpening maybe?.. Thanks
01-24-2024, 06:48 PM
There is an easy trick to get the most out neat. Upsizing x2 before messing with it.
Deinterlace (lossless mode)+ upsize ×2+neatv5+ sharpening
That should be a good formula imo
01-24-2024, 08:58 PM
The first thing I can see is that your VCR doesn't have a built-in TBC.
01-25-2024, 06:37 AM
OK but will a built in TBC deal with this particular horizontal lines issue?
01-25-2024, 09:13 AM
"There is an easy trick to get the most out neat. Upsizing x2 before messing with it.
Deinterlace (lossless mode)+ upsize ×2+neatv5+ sharpening"
Thanks themaster1, Have to try that one, any particular filters, Avisynth scrypt maybe? For the neat video I go to premiere pro where my demo is.. Thanks
Hi traal. As I mentioned before my VCR is JVC HR-S9850 with a built in TBC and my examples above were captured with it.. I tried many different options (with and without), this one that I post now is WITHOUT TBC but with Stabilizer instead. No processing were made on it, bottom overscan looks better IMO.. Looking for your opinion, thanks
02-03-2024, 12:42 PM
This one is same like above (no TBC, Stabilizator instead + script+ neat video). Lines are now better but faces are blurry..
FFmpegSource2("GrodeSTABshort.avi")
AssumeTFF()
#vsCnr2_vsCnr2(mode="oxx", scdthr=10.0, ln=35, lm=192, un=47, um=255, vn=47, vm=255, sceneChroma=false)
Prefetch(4)
Any idea what I can do about the clearness of the faces in this kind of video (and I have to deal with many theater shows like this with old fashion cameras far away). Is it possible to improve it?
Maybe some small avisynth script ?
Thank you very much
