04-01-2011, 11:13 AM
designunlimited designunlimited is offline
Hello All
First time user of this forum. Looks like a very interesting place to share problems, and get solutions.
I am new to audio. I had a friend who had recorded this clip, but the audio file is unhearable. Is there any way I can remove that distortion in this file. thanks in appreciation.
Please download this file and see if you can help me:
http://www.designunlimited.org/audiofile.wav
regards
subly
04-01-2011, 11:36 AM
This is not an audio issue, but rather a codec management issue.
The original audio has been lost, as this WAV file is a save of a badly decoded audio format.
For example, lately we've worked with a lot of Dolby E audio. While a number of programs "seem" to open the audio file, and will re-save it to something else (WAV, AAC, MP3, AC3, etc), all you'll get is this same loud buzz. The distortion is so bad, in fact, that it could ruin speakers. Dolby E must be properly decoded, either downmixed to stereo with an Avid Pro Tools 8 plugin, or a mono transcode through VLC.
You'll need to figure out what the original audio format was, and then properly open it, then re-save it to WAV (or whatever format it is that you're needing for the project).
This may be something that you caused, or it could be something your friend did before you ever got the file. Either way, what you have is a "nothing" file -- there is no audio in there. This WAV is worthless and can be discarded. Hopefully you still have the pre-WAV audio recording.
Another option is the recorder is damaged, and is not recording audio. However, this is less likely than a simple decode issue.
DTS audio file, unable to hear after authoring? manthing Encode, Convert for discs 3 02-12-2018 05:09 AM
Fixing VHS-C audio problems - Project Notes for Al kpmedia Restore, Filter, Improve Quality 0 08-19-2010 07:40 PM
Fixing VHS tearing during capture; JVC D-VHS vs. JVC S-VHS VCR? lucgallant Capture, Record, Transfer 10 05-09-2010 07:15 PM
Fixing audio that comes out of one speaker Superstar Restore, Filter, Improve Quality 3 03-01-2010 12:13 AM
Need help fixing aspect ratio wayshway Videography: Cameras, TVs and Players 8 04-30-2008 04:10 PM
