09-15-2017, 10:13 AM
lollo2 lollo2 is offline
I have recently captured a set of S-VHS tapes recorded long time ago from a DVB-S program (video to restore); a sample image is attached.
I used an Hauppauge USB Live 2 with all proc amp settings at default values (half scale) and HuffYUV codec.
One year later the S-VHS recording, I was also able to record the same program with a direct dump of the original satellite stream thanks
to a new dvb-s pc card (reference video); a sample image is attached.
I am not at all an expert about video parameters, but when I compare the 2 images, they look quite different: something has been
lost/degradated/changed in the Digital-to-Analog and Analog-to-Digital conversion on the first flow, which I assume is normal.
Is there any way using VirtualDub or AviSynth filters to "restore" the first video to match the "reference" video in some "automatic way",
for example run some procedure on the 2 videos finding the differences for the video parameters and apply a correction?
I understand it will not be possible to match the better definition and "look" of the original, but may be some improvement can be done on
the captured video...
09-15-2017, 08:52 PM
I'm wondering why one would think a later digital source and an analog source would look alike. S-VHS wasn't nearly so great, even in its heyday. Also wondering why you don't just use the digital version.
The Colourlike Avisynth plugin has been used to make similar sources look alike.
Latest v1.0 download (.dll with .txt file + source code): http://wilbertdijkhof.com/mg262/Colourlike_v10.zip (or see attached)
original discussion: https://forum.doom9.org/showthread.php?t=96308
updated documentation: https://forum.doom9.org/showpost.php...5&postcount=38
09-16-2017, 02:45 AM
lollo lollo is offline
Many thanks for your reply and the links, sanlyn, I appreciate.
You are right, and I did not think s-vhs recording could match the original broadcast.
I was just wondering if some post processing could be done to match the "overall video perception", because the first thing I noticed in the
comparison is the "different colors" (I apologize for the non correct video terminology).
I am a fan and a collector of that series, and at some point in time during the second run, the TV Station changed logo, so i also would like
to capture the first run I recorded on s-vhs to have a "homogeneous look".
Intelaced with USB grabber, processing Video fakir Capture, Record, Transfer 6 12-03-2016 11:07 PM
Request advice for filters/post processing Vhs capture from sample threepeak Capture, Record, Transfer 0 07-22-2016 09:20 PM
Trying to capture analog video tapes to digital with Canopus ADVC AVNorm Capture, Record, Transfer 3 02-25-2014 03:17 AM
How to deinterlace MP4 video + batch processing? segen77 Restore, Filter, Improve Quality 3 02-13-2014 11:43 AM
Strange Mainconcept Reference error... video stops while the sound continues ? via Email or PM Encode, Convert for discs 0 12-06-2011 11:23 PM
