Go Back    Forum > Digital Video > Video Project Help > Encode, Convert for streaming
11-12-2013, 02:29 PM
rand107 rand107 is offline
Hi Guys and Girls,
Im a complete newly to this, so, apologies if its not in the right thread or if this problem has been solved many times over - I know how annoying that is.
Right here we go.
So I've created a rather nice video of me sat playing guitar and singing, recorded through Quicktime, the video is about 3mins 14 secs. Only problem is its got my ugly mug on it, so, being a bit creative, I processed it using MPEG Streamclip to break it down into 1913 JPEG files, batch processed all of them using AKVIS Sketch and then recombined them back to a Quicktime mov using MPEG Streamclip, result - a nice sketch/animation of me singing. The only problem is that somewhere in this process I've lost 6 secs of video (images) and when I now combine with audio, it is out of sync. I can't offset the audio because it gradually loses sync. I've tried using Logic Pro to time stretch the audio and speed it up, but, yes you guessed I sound like a chipmunk. My last kind of idea is to add what would 6 secs of frames (about 58 Jpegs) to the process then recombine but, is there an easier way than this.. I've read somewhere about using a AssumeFPR function, is this a frame rate issue? Help!!!
I should add that I've limited video editing software. iMovie, Quicktime, Handbrake and VLC.
Many Thanks in advance.
Rik
07-29-2014, 08:08 AM
Old post, but wanted to share the advice anyway...
You have several options here:
- add more frames to correct the sync
- shorten the audio, then correct the slight "chipmunk" sound by altering the audio pitch
In all honesty, it sounds like a simply PAL/NTSC mix-up somewhere in the workflow. And it the project was/is still saved, it would be simple to go back and correct the project settings.
This was an unanswered question or unresolved issue found during a site audit. It's hard to have an FAQ when the answers are missing, or final outcomes are unknown. At The Digital FAQ support forum, questions are never intentionally ignored, and may have been missed due to a forum glitch or human error. More details on the audit. (In some cases, threads have been edited/updated with newer information.)
VirtualDub - constant frame rate vs. variable FPS? Zerowalker Capture, Record, Transfer 6 01-10-2014 04:02 PM
Interlaced video to progressive (double frame rate) metaleonid Edit Video, Audio 23 09-29-2013 09:51 PM
Frame rate trouble in DVD Architect Reading Bug Encode, Convert for discs 15 12-31-2009 01:39 PM
Audio sync problems with Womble MPEG2VCR mlaviolette Edit Video, Audio 3 10-14-2006 11:53 AM
Audio-video out of sync, other problems yargellham Capture, Record, Transfer 7 11-20-2005 02:28 PM
