10-27-2004, 11:02 PM
jrnyhead jrnyhead is offline
I just borrowed PhotoShop v7.0 from a friend, so I can try this software that everyone talks about to create my DVD inserts.
Question: Everytime I open an image, it is set to RGB color. How do I open a image in the same color's as the .jpg I downloaded from my camera?
10-28-2004, 08:43 AM
JPEG are RGB. Most of them use sRGB colorspace too.
10-28-2004, 09:13 AM
Sorry, maybe I didn't make myself clear. When I open an image in Photo, the image is a totaly different color than my orginal photo. For exmaple, a brown rock looks green, green grass looks purple. When I use, for example Microsoft Digital Image, the image I pull into the software looks exactly like the image on my hard drive, there is no color difference. When I pull an image into Photoshop, the colors are changed atuomatically to RGB colors, thus brown looks green.
10-28-2004, 12:02 PM
The camera may use a special colorspace for stills. If this is the case, you may have to extract images with the software that came with it. Then open them in Photoshop after they're transferred.
Create Motion Menus with Adobe Premiere [QUICK GUIDE] lordsmurf Author, Make Menus, Slideshows, Burn 4 04-01-2009 07:45 AM
Photoshop Plug In battle7 Author, Make Menus, Slideshows, Burn 1 10-22-2006 05:57 AM
Photoshop authoring help fortunec00kie Author, Make Menus, Slideshows, Burn 6 04-19-2006 04:35 PM
Adding unlimited text in Adobe Pro 1.5 jrnyhead Encode, Convert for discs 2 05-26-2005 02:05 PM
Adobe Premiere 6.5 - good deal for boxed version ? jrnyhead Edit Video, Audio 1 08-05-2004 07:28 AM
