05-08-2015, 11:45 PM
rocko's Avatar
rocko rocko is offline
Please excuse my ignorance, What Brand is a WV-F250?, and what format does/did it shoot in?
05-08-2015, 11:55 PM
Dead Christmas's Avatar
Dead Christmas Dead Christmas is offline
It's a Panasonic, I think it shoots "analog", but the dockable unit records DVC-PRO onto the VHS tape, I swear I read that in the manual.
05-09-2015, 05:25 AM
Some analog video terms that might help the OP.
- Hi8 is a legacy analog video tape format, similar in quality to S-VHS. It differs form 8mm (and VHS) by having somewhat higher resolution in the b&w portion of the transmitted image.
- BNC is a type of coaxial connector typically used on commercial/professional gear for low power signals above the audio frequency range, including video. It has advantages of being a locking connector and lower signal losses.
- XLR (or Cannon) connector is used for audio and sometimes power on commercial/professional gear.
- RCA or phono is a name often used for the low cost coaxial type of connector used on consumer gear for low power audio and video signals.
- phone (and mini phone) refer to the 1/4" and 1/8" diameter jacks often found on headphone audio connectors. They come in 2, 3, and 4 conductor variants and are typically used for audio and instruments (e.g., guitars).
- composite often refers to a type of video signal in which both the b&w and color information are combined for transmission on a single coaxial cable. It typically is associated with a yellow RCA jack on consumer VCRs.
- s-video refers to separate video where in the b&w and color information are carried on separate coaxial cables. It typically uses a 4-pin mini DIN connector. It is mainly found on S-VHS, Hi8, DV, higher end TV sets and projectors, older DV & Blu-ray players, and cable set top boxes.
- component often refers to a video signal that uses three connectors/cables for the video signal, typically the red, blue and green RCA jacks on consumer gear. However, the signals themselves contain b&w (on green) and color difference (on red and blue) information.
- prosumer - a term often used to describe gear that is in the price and performance space between high end consumer electronics and entry level professional/commercial equipment. This has been a favorite of moderate budget event videographers (e.g., weddings) and some public access cable.
Any gear from 20 years ago is a crap shoot. Prosumer/industrial gear stands a slight better chance of being supported somewhere for maintenance/repair, but may have seen higher use than consumer gear. The best hope is prosumer gear from a household where everyone had a full time job and no time to use the VCR much for time shifting or rental tapes. How good is VHS? S-VHS? The fact that commercial broadcast did NOT use it for anything important or prime time if an alternative was available tells the story.
As to buying legacy analog gear, short of being able to test the gear before making the purchase, shopping from a well-established used broadcast gear recycler may be a good assurance of an honest equipment condition description.
I believe that the OP is hell-bent on using the vintage camera to record to consumer analog tape. Alternatives that use current technologies that address the failings of the old consumer technologies are of no interest to the OP. It matters not that VHS was a compromise based on developing a video record/playback system that could produce a first generation image on available tape technology acceptable to most consumers on the TV sets of the day at the least possible manufacturing cost.
The following users thank dpalomaki for this useful post: Dead Christmas (05-09-2015)
05-09-2015, 09:17 AM
I came over from cassette, as I was very impressed with the results provided by the tapes in my possession. I figure: "Hey, maybe something like VHS will have great analog results, too!" And it mostly holds true, as I'm satisfied with the quality of VHS both pre-recorded and made by others, and myself. I'll admit, it sucks re-winding just to try and find my spot on the tape, but that's just because I haven't got a VTR with a counter.
Other than age, I don't see what's wrong with S-VHS, or even VHS (other than companies like Panasonic being obscure about what gets converted, or recorded to digital on what should be an "analog" system > ).
My EasyCap is arriving today, since I cannot find the software to adjust my TV-Wonder's input resolution, and I end up just re-sizing to 480p. I hope this correction of resolution will lead to even more impressive results!
Honestly, my only gripes are with my shaky tripod, and the lack of a counter VTR.
But...I thank you for taking the time to explain it like that to me. It's unfortunate that a better analog tape system couldn't have been produced. Look at what audio cassettes managed, and it seems that most people won't even compare the audio quality between the two formats, which, I believe are technically the same aside from size and ips.
05-09-2015, 12:57 PM
The are better, much better, analog video tape formats than VHS, but they did not reach down in to the consumer market.
VHS linear track audio is, with few exceptions, mono, and the pits. But then so was typical 1980's vintage TV set audio. Stereo HiFi on VHS gave roughly FM radio quality.
Audio cassette quality was also pretty bad until the advent of Dolby, DBX, and the significantly improved tape formulations in the 1970s and early 1980s or so. (For a long time the #1 road side litter (after beer cans) was failed audio cassette.) But compared to AM radio it was OK.
05-09-2015, 02:31 PM
Example: BetacamSP
05-09-2015, 09:12 PM
Ooh...This Betacam looks interesting, what's it got to offer over VHS? I'd like to hear it from an expert's mouth, not Google's.
05-09-2015, 10:19 PM
BetacamSP was the dominant analog ENG format used in the broadcast industry from the 80s to about the mid-90s to late 90s when digital formats became commonplace (DVCPro and Betacam SX are some of these formats). It stores luma and chroma on two separate tracks on the tape. Its luma quality isn't as good as the "high band" Hi-8 or SVHS formats, but the chroma on a separate video track blows the consumer formats out of the water. As for the camera, the WV-F250, all video taken with it is going to be digital since it is a CCD camera, it converts the output to analog to record on SVHS. The only true analog cameras were tube based, which is a whole different ball game. Think heavy, power hungry, and a pain to keep working right. Oh and the image quality usually stinks on shoulder sized tube cameras.
05-09-2015, 10:32 PM
So technically, information written to Betamax tape is digital, too?
05-09-2015, 10:35 PM
When I started in on video, some 20+ years ago, in the analog days, pros used BetacamSP, and serious hobbyists, low-budget pros, and schools/colleges used S-VHS. I never got into BetacamSP, as I've never been a shooter. At that time, I was just a serious hobbyist, using S-VHS and the "cheat" S-VHS-ET (S-VHS on VHS tape). By the time I went pro, the early digital formats were already here (MPEG-2 and DV).
I was never really a shooter in my hobby days, though I did do some S-VHS stuff. It was blah, not much better than VHS. I was always into editing, restoration, and re-recording pre-existing pro sources (cable TV, etc).
Of course, I'm still not really a shooter.
DV is so-so, DVC is better. These days, I'd go straight for a camera that shot MXF (Canon or Sony) for pro work.
I shoot tripod-mount on a DSLR now, 720p @ 60fps (reduced rolling shutter), decimate by 2. But again, I don't shoot much.
EDIT: BetacamSP is NOT the same as Betamax!!! Don't make that mistake.
05-09-2015, 10:46 PM
Err...Then Betacam SP is technically digital?
05-09-2015, 10:52 PM
Betacam SP is analog.
05-10-2015, 12:04 AM
http://www.ebay.com/itm/RCA-Newvicon...item2c9a6fe381
So, does Betacam SP have it's own "Set" resolution? Or is that a variable left up to the capability of the camera?
Might get one of these if that's the case. Very pretty looking analog unit that could be paired with a Betacam SP recorder for pleasant results!
05-11-2015, 06:51 AM
BetacamSP was structured to provide a signal for use in broadcast video. Thus the slightly lower luma resolution compared to the Hi8 & S-VHS formats. But it likely had a noticeably better signal to noise ratio and flatter frequency response within the design bandwidth. Thus it survived multi-generation editing/copying much better than the consumer Hi8/S-VHS/VHS/8mm formats.
The camera internals are a mix of analog/digital for image acquisition, but the output signal to the recorder is analog video.
Until recently NTSC broadcast video was all analog, nominally 330 lines of video resolution (B&W image portion). Hi8/S-VHS provides nominally 400 lines of video resolution, and VHS/8mm about 240 lines (on a good day). The DV formats provides about 500 lines. Resolution is the number of alternating black and while vertical bars that can be distinguished in a horizontal span equal to the image height (480-486 lines for NTSC SD). It is somewhat subjective and what you see depends greatly on the quality of the display used.
Another other issue is the frequency response. One MHz of horizontal bandwidth corresponds to roughly 80 lines of video resolution. But if the record/playback response has a dropping frequency response curve, say down 15 dB at 2 MHz (~160) lines and still visible bars, the next generation copy will be -30 dB, and probably no longer visible bars. (Figures for illustration purposes only.) The bandwidth (resolution) of the color portion was much lower, on the order of 40 video lines, but that was all the average human eye needed to provide a usable image in the early days of color TV. That is part of why VHS copies are so bad.
The BetacamSP format is well matched to SD broadcast video.
Many items of legacy video gear contain digital circuits internally. The Canon A1 Digital and L1/L2 Hi8 camcorders had them for DSP and effects, and playback processing, but the video format on tape, and the output was analog video and audio.
The video signal format is set by the NTSC standard. The quality of the final viewed video is limited by the weakest link in the chain and the cumulative effects of each step in the chain.
If the camera is 3 dB down at 200 lines + some noise
The Recorder is 6 dB down at 200 lines + some noise
The Player is 6 dB down at 200 lines + some noise
the TV is 2 dB down at 200 lines + some noise
What you see on screen will be 17 dB lower than the real life subject with 4 increments of noise added.
That is why digital formats can do much better - no losses or noise beyond the original encoding and final display decoding.
The following users thank dpalomaki for this useful post: lordsmurf (05-11-2015)
  #35
05-11-2015, 09:52 AM
This might fly in the face of everything this board stands for...but...I'm not concerned with quality here. Really, only damaged tapes, or ones with visible compression artifacts bother me. Of course, I've got a limit on how low resolution can be (VHS is kind of pushing it...)
http://www.ebay.com/itm/VINTAGE-JVC-...:X:AAQ:US:1123
Something like that (I did a bit more research, and found that the Newvicons were single-tube, subpar units.) would be more than enough for me, and who knows, just looking at it I think I'd have more fun making the recordings that watching them!
Looks like these Betacam SP decks are all either "professional editor" decks, or J-3, or J-1 units? Any recommendations for one that'll produce nice results?
05-11-2015, 01:15 PM
Read more: http://www.digitalfaq.com/forum/newreply.php?do=newreply&noquote=1&p=38212#ixzz3Zr 41eYzS
You are correct. If quality (as well as portability and workflow) are not an issue, then I would say buy what ever strikes your fancy and fits your budget, and have fun.
05-11-2015, 01:46 PM
This was an excellent post.
05-12-2015, 04:03 AM
I don't suppose there was ever an HD Analog video format beyond W-VHS?
I'm absolutely not against better video. If I can get better resolution, then I'd be more than willing to spend the money of whatever obscure format that offers both high-resolution, and analog video.
What I don't understand is why Analog video couldn't have resolutions like 900p, or even 1080p? Is that a problem with tape-width, or were the electronics not able to handle a resolution like that?
05-12-2015, 06:52 AM
The issues for HD analog video recording formats are bandwidth, cost, and demand. No one would pay what it costs to do it well, especially when current digital formats can do it well.
The component HD output (if available) from a HD source such as a set top box or BD player is HD analog up to 1080i. It is generally digital on the media (typically compressed as MPG or AVCHD) or in the transmission channel.
The electronics can do it, but tape is more problematic. For clean 1920x1080P, 60 FPS, HD quality analog recording you would need a tape format that can record and playback signals to ~75 MHz with a 50 dB signal to noise ratio and reasonably flat frequency response. Not a trivial task.
S-VHS tape is something like 8 MHz bandwidth and around 46 dB S/N on a good day. The broadcast SD NTSC video channel bandwidth was 6 mHz.
Note that all commercial color TV sets were effectively digital-like displays, even the tube types. The color image was essentially comprised of individual R B & G phosphor dots behind a shadow mask/aperture grille. The later Trinitron-like tubes had vertical stripes, but the individual scan line essentially chopped them into dots as well. The electron beam was analog, but the visible display was comprised of luminous spots on the screen. (We will ignore the color wheel designs that never really sold.)
The following users thank dpalomaki for this useful post: Dead Christmas (05-12-2015)
  #40
05-12-2015, 07:23 AM
I've done some thinking...Maybe a digital camera would be best...
I guess I should have given some background: My obsession with analog was started with my frustration with music producer's driving an album's levels into the ceiling...'cause loudness, I guess. Originally, I hadn't bothered with video being analog, but I guess my separation of the two had become blurred.
I will need to seek information on budget video cameras in a separate thread, but I will also continue to try and buy tapes on cassette. That's, to get the music in its original, and "un-molested" form...
I'd like to thank all of you for bringing me to my senses. My wallet might be a bit salty about it for a while, in part due to to a revamp of my setup, but I'm sure it'll be worth it in the end when I'm not paying 20$ a piece for a metal tape, or 300$ for a roughly 480p camera from 1970.
Buying a video camera for recording interviews? mrs.faith Videography: Cameras, TVs and Players 3 02-08-2018 09:25 PM
DSLR camera stopped recording video for no reason? Mr. Rey Photo Cameras: Buying & Shooting 1 12-16-2014 06:13 AM
Which SVHS Deck for best audio output? andymation Capture, Record, Transfer 16 03-14-2013 04:36 AM
Panasonic AG-1980 playing non-SVHS as SVHS? cyber-junkie Videography: Cameras, TVs and Players 15 04-21-2010 03:48 PM
