07-14-2023, 08:00 AM
Legi0n Legi0n is offline
I have been collecting some retro games for original Xbox, Xbox 360 and Xbox one.
Some of the discs have some minor scratches. I want to make sure they are all in a 100% working condition and 100% readable/healthy.
Someone suggested that I should dump the discs and then compare their md5sums to the md5sums at redump.org... I don't want to do this because this is a major headache(To dump the discs I have to buy a specific drive and then flash the firmware on it ... and alot more).
That leaves us with scanning the discs for errors...After searching and searching I came across this guide.
it suggests :
- Doing a Surface scan with a GOOD drive.
- Doing a transfer rate test (TRT) with a GOOD drive.
- More advanced tests but the guide says: " they are of little value to most people, often serving as nothing more than “facts” for arguments in online user forums."
My questions:
- What is a GOOD drive ? I have an LG WH16NS40 and a Toshiba/Samsung SU-108 laptop DVD-ROM drive. Are these considered "GOOD" ?
- For DVDs/CDs which program should I use for a surface and a TRT scan ? The guide suggests using Nero Disc Speed / Nero CD-DVD Speed or DVDInfoPro ?
- For BDs which program should I use for a surface and a TRT scan ?
- Do you recommend the advanced tests mentioned in the article ?
- Any other tests that I can do ?
- Can a drive damage the disc when scanning it ?
- Any articles/guides on this subject ?
Many Thanks
Mini DVDs lose data in a few hours, won't verify? larryaxtell Blank Media 11 09-18-2015 07:03 PM
Best Router for various things - XBOX 360, laptops, desktop computers Superstar Computers 28 02-26-2011 12:43 PM
Verify after burning with ImgBurn? What's a TRT scan? PIE/PIF? via Email or PM Blank Media 4 06-27-2010 09:50 PM
XBOX error: This disk is damaged or dirty CaZeek Computers 1 12-19-2004 07:55 PM
